Old 07-29-2009, 08:58 PM   #4
MGargano
Drives: 2009 Yaris Hatchback
Has anyone else found their Yaris to be asymmetrical in the rear? I have 13mm hub spacers installed and the right side definitely sticks out further than the left. I wouldn't mind so much except that the right side is rubbing when going over dips in the road, which is annoying. Aside from the washers, is there any plastic (etc) that I can safely eliminate to stop the rubbing?
MGargano is offline   Reply With Quote
Aftermarket exhaust systems that do not rub on the road! fuji Performance Modifications 10 04-28-2009 06:22 AM
Does +43mm rub? Split Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 02-28-2009 07:39 PM
New Wheels and TRD springs tires rub gmodder Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-25-2009 11:21 AM
want 2 lower with tein but have tyre rub HELP! MR. CANTON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-24-2007 04:16 PM
Ruba a dub dub in the rear slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2007 08:27 PM
