#361 |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
ITS ALIVE IT'S ALIVE
A fu*king ignition module was the reason. Thanks to haltech support I was able to solve the problem after they got me replaced with new coils instead. Now it idles like a sweet girl smiles at you and rev up like never before and this only with a map sent from haltech!! Now I need to install the last few bits: - NST 3x pulley kit - Nitto torque damper - Celica 2ZZ-GE intake manifold + 2ZZ-GE 72mm throttle Body Also I noticed that from the output hole of the turbo (that goes into the intercooler piping) it leaks some oil from it. It happens when revving much the engine. Could be the seals of the turbo that need replacement or should I leave it? What I need to do? Is it expensive to repair it? What are the items needed? |
#362 |
congrats that is awesome
#363 |
#364 |
What's your oil pressure like when u rev it?
#365 |
And look what arrived yesterday!
A 2ZZ intake with a 70mm throttle body! Tried fitting on spare engine and there are only minor issues to solve : - To mate the 1NZ intake flange with the 2ZZ intake - Some clearing issues on the front ( It could be that the intake hit radiator piping) - Right Mounting holes - Increase length of right intercooler pipe due to throttle body at an angle If this works I cannot say what are the gains but at least I can show that it can be done! Last edited by Parmas; 11-28-2010 at 04:19 AM. |
#366 |
Please check this thread.... http://www.yarisworld.com/forums/sho...932#post539932
#367 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
cool build!
Ptuning.com |
#368 | |
Now I am tuning the engine myself and till now I done mapping of the engine with 9psi boost and 5000rpm [with AFR LOW 14 / HI 10.5 (boost) ]. This week I am preparing the car for the final tune which is the 2ZZ intake. If all goes fine, I have to retune the engine for the larger o/d of the 2ZZ intake Throttle Body (70mm) and runners
#369 | |
Ptuning.com |
#370 |
Mr. 155 and climbing
the human head weighs 8 pounds
#371 | |
I am no expert on tuning, and with this unit I was capable to tune a reliable 9psi boost till 5000rpm (at least for now :) ) I am hoping better response with this intake. Let's be straight, If any would tell you what do you prefer between a custom intake or a Toyota proven one, I vote for Toyota and here it is! ![]() I hope it will be ready for a christmas present to my self
#372 |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Can you explained to me what is your logic on using a manifold from an engine that is 1.8 liters & revs 8000rpm on a 1.5 liter that revs 6300rpm? Are you aware that intake manifolds are designed to work within a specific RPM range? I dont get why you would think that the factory manifold from the 2ZZ would be a manifold than a custom one engineered to work for a specific engine combination.
#373 | |
2. I am sure it is the case, but who cares now that I am turbocharged. The stock intake wasn't designed to be used with forced induction. 3. The only answer for this is the price. The 2ZZ manifold + 2ZZ TB cost me half or lower than a quoted custom intake manifold only! |
#374 |
Do you have any pictures of the progress on the manifold? Is he just custom fabricating the upper portion of the manifold so it fits the 1NZ head and the lower part of the 2ZZ manifold?
#375 | |
2)You are correct about the stock manifold, but no one has reached the max limits of it. And the 2zz was also never designed for boost. 3)You will never get anywhere by cutting corners, especially price. Cheaper is never better. There are many reasons custom intake manifold are expensive. |
#376 | |
#377 |
I dont & will never claim to be an expert, but thx for the compliment ; )
I can tell you that long manifold runners are not made for boost, short runners are. So a manifold with shorter runners would improve airflow on boosted application. But there are many factors that need to be taken in cosideration such as: Turbo size Boost level Cylinder head flow Intended use (street or strip) Im going to read over all of Parmas posts to give you my thoughts on the matter.... |
#378 |
After reading 21 pages of post all I can see is an engine that makes 250hp & that Parmas cant stop adding parts to his car. He need to stop making adding thinga & tune & dyno the car as it is. Thats my 2 cents...
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
