#1027 |
play every day
Namer convinced me not to mess with my header. Anyways, I like the Weapon R design and so will be leaving it as it is. I do have some more experimental intake manifold ideas that I want to see what happens if I do them. It's like following a tiny silver thread and you never know where it leads.
#1028 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
I was also going to guess exhaust... but with you living in Los Angeles, I imagine you cannot even think about messing with the catalytic converters without fear of the man breaking down your door.
I'm about to move to a full 2.25" header-back exhaust using a OBX exhaust system as a base along with a single 2.25" magnaflow cat, 2.25" magnaflow resonator and 2.25" magnaflow muffler. I've also been thinking about buying another DC header and having the collector modified to 2.25", being that it is 2" now. I know there is more HP in there if the exhaust system can get freed up a little more. 2" seems so small for a collector on these headers, all of the 1.6L Honda's I worked on were either 2.25" or 2.5". Either way, I need to find a shop to get this thing dyno'd so I can get a baseline. Thanks for so diligently getting your car dyno'd, it's great to see actually numbers instead of 'seat of the pants' reviews on stuff. |
#1029 | ||
play every day
![]() ...and it'll smog test just fine. Quote:
![]() The graphs are honest and all done under the same conditions. Nothing was done to either enhance or diminish the results. I did three stock baseline runs, three with the tooter alone, and three with the tooter and the 1ZZ throttle body, and posted the best run from each set. |
#1030 |
play every day
Harry, at HK Motorsports dyno shop suggested tuning would increase the power but I won't be doing that. It already does good enough with the stock tune and regular pump gas... and I still want it to be able to pass the smog test. So I'll leave that for someone else to experiment.
#1031 |
^ Hopefully you'll pass visual. It does look stock, but it isn't, and technically should not pass.
But hey, it's a 2012 right? You have at least five more years I think. I haven't had to smog my '07 yet!
#1032 | |
play every day
#1033 |
Only Happy When it Rains
so absurd you can't pass smog with mods. where is the scca on that front?
Colin Chapman disciple |
#1034 |
play every day
#1035 | |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#1036 |
![]() ![]() ![]() Drives: 2017 L 3-door Join Date: Mar 2011
I may be late to the show but...
I think there's still hp left on the table. Looks like the 108 whp is just about every bolt-on mod aside from the crank pulley, which is considered by many to be the best "bang for the buck." |
#1037 |
play every day
I don't believe that the pluses outweigh the minuses in that regard, as I don't think it's a good idea to remove something from an engine that provides the useful purpose of absorbing crankshaft vibrations.
#1038 | |
Also tooter, do you still have the 1.75" exhaust piping after the factory resonator still in place? It might be worth paying the small amount to have that replaced with a 2" or 2.25" back to the axle-back. Also, I recently replaced my crank pulley with a MI crank pulley and I didn't notice much if any change in engine output. I did notice however that the car is easier to drive, matching revs and such. For having nothing but manual transmission cars my entire life, I drive my Yaris somewhat jerky. I would say I drive the car a bit smoother now as I go through the gears. Eventually I plan on getting a lightened flywheel, I've had them in multiple cars in the past and it makes a huge difference in the car. |
#1039 |
If it's a horrible idea, why did Garm spend R&D building them?
#1040 | |
play every day
When each cylinder chamber fires the force is transmitted through the piston down the connecting rod to the crankshaft. This force is not applied smoothly, but is a series of pushes. So when the crankshaft rotates from the cylinder pulses, the rubber connecting ring between the center of the pulley and the outer section allows the center to alternately rotate momentarily faster and slower than inertial weight of the outer section which rotates more smoothly. This helps to absorb the crank vibrations to make the engine run smoother. In high performance engines under racing conditions, this is not a consideration. So parts are engineered to meet high performance racing oriented priorities. |
#1041 |
except that is not the case. That was the case in the 60's, and is still the case today in some larger v-8's, but it is in no way the case in a modern 4 cylinder engine.
Have you taken a look at the Yaris' pulley? There is basically no rubber on it at all. A modern 4 cylinder engine is balanced internally, that is the engine itself is harmonically balanced, and it does not need external harmonic dampeners of any type. how many millions of problem free miles do aftermarket pulleys need for this talk to finally be buried like the falsity it is?
#1042 | |
play every day
![]() I didn't know that the stock Yaris pulley was solid metal. So then it doesn't matter what you run. |
#1043 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
a popular 4 cylinder factory balancing technique is to use balance shafts the are driven by the timing chain and turn in the opposite direction of the crank shaft. I'am not aware of any newer 4 cylinder engine that require external crank shaft dampening.
I'm with Why, there is no dampener pulleys on new age 4 cylinder engines.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#1044 | |
play every day
Now you guys got me all curious, so I took an inspection mirror and actually looked at my pulley. It's got a rubber dampening strip in it. Maybe the 2012's are third gen that they have them now. I also found a pic of one like mine. It looks exactly like this... |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
