Old 07-29-2009, 08:58 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
Has anyone else found their Yaris to be asymmetrical in the rear? I have 13mm hub spacers installed and the right side definitely sticks out further than the left. I wouldn't mind so much except that the right side is rubbing when going over dips in the road, which is annoying. Aside from the washers, is there any plastic (etc) that I can safely eliminate to stop the rubbing?
MGargano is offline   Reply With Quote
Old 08-01-2009, 07:51 PM   #2
Mead
Drives: BSP Yaris LB 2007
mine too, passenger side sticks out prolly >5mm
and the rubbing is around the rear bumper split line... not top center
Mead is offline   Reply With Quote
Old 08-01-2009, 07:55 PM   #3
MGargano
I think that's where mine was rubbing too, along the bumper split line. Try the washer thing.
Old 08-02-2009, 03:44 AM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
I had 4mm differance between the Right Rear and left rear,
beleave it or not , 2.5-3mm of that was guard miss alignment ,
which took the Toyota tech 3mins too fix (pulled guard out )lol
the rest of the rear was well within factory specks .
Aftermarket exhaust systems that do not rub on the road! fuji Performance Modifications 10 04-28-2009 06:22 AM
Does +43mm rub? Split Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 02-28-2009 07:39 PM
New Wheels and TRD springs tires rub gmodder Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-25-2009 11:21 AM
want 2 lower with tein but have tyre rub HELP! MR. CANTON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-24-2007 04:16 PM
Ruba a dub dub in the rear slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2007 08:27 PM
