#1 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
Now I am tuning the engine myself and till now I done mapping of the engine with 9psi boost and 5000rpm [with AFR LOW 14 / HI 10.5 (boost) ]. This week I am preparing the car for the final tune which is the 2ZZ intake. If all goes fine, I have to retune the engine for the larger o/d of the 2ZZ intake Throttle Body (70mm) and runners
#2 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Ptuning.com |
#3 | |
I am no expert on tuning, and with this unit I was capable to tune a reliable 9psi boost till 5000rpm (at least for now :) ) I am hoping better response with this intake. Let's be straight, If any would tell you what do you prefer between a custom intake or a Toyota proven one, I vote for Toyota and here it is! ![]() I hope it will be ready for a christmas present to my self
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Can you explained to me what is your logic on using a manifold from an engine that is 1.8 liters & revs 8000rpm on a 1.5 liter that revs 6300rpm? Are you aware that intake manifolds are designed to work within a specific RPM range? I dont get why you would think that the factory manifold from the 2ZZ would be a manifold than a custom one engineered to work for a specific engine combination.
#5 | |
2. I am sure it is the case, but who cares now that I am turbocharged. The stock intake wasn't designed to be used with forced induction. 3. The only answer for this is the price. The 2ZZ manifold + 2ZZ TB cost me half or lower than a quoted custom intake manifold only! |
#6 | |
2)You are correct about the stock manifold, but no one has reached the max limits of it. And the 2zz was also never designed for boost. 3)You will never get anywhere by cutting corners, especially price. Cheaper is never better. There are many reasons custom intake manifold are expensive. |
#7 | |
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
