Old 01-10-2013, 01:26 PM   #11
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by Bluevitz-rs View Post
I don't remember if it was asked at all, but does this manifold sit any closer to the rad than the plastic one?
Just measured. The minimum distance between the tooter and the plastic radiator reservoir is 30mm. This is the the point where it comes closest to the radiator assembly. It's not nearly as compact as the stock manifold because the runners are larger diameter and curve around a lot so that they will all end up being exactly the same length.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
