Old 01-12-2013, 11:22 AM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by Bluevitz-rs View Post
I think you're confusing it with a 2 stroke. Atkinson cycle is the same as Ottos. The only difference is that Atkinson has a shorter compression stroke than power stroke. On the Prius, this is achieved through intake cam timing and duration. The intake valve is held open much longer allowing some of the intake charge to be pushed back on the compression stroke reducing the energy required to compress the intake charge. This in turn rises the efficiency of the engine by effectively making the power stroke longer extracting more energy.
You're right. Hybrid engines acheive the Atkinson effect with valve timing.
Found this by searching How does a Prius hybrid engine work:
"Its engine only runs at an efficient speed and load - In order to reduce emissions, the Prius can accelerate to a speed of about 15 mph (24 kph) before switching on the gasoline engine. The engine only starts once the vehicle has passed a certain speed. And once the engine starts, it operates in a narrow speed band."
The bottom line is that installing a different throttle body on the engine might impair the optimum performance in that very narrowly tuned rpm range.
This explains why they use that weird intake manifold.
Old 01-13-2013, 05:58 PM   #2
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Currently I have enabled the EV mode hack which is standard on the EU and JDM Gen2 Prius This allows the prius to use the Electric motor only up to 34mph as long as the there isn't much demand for power. If I romp on the gas from the start - during heavy acceleration or hills both the ICE and MG2 move the car along.
Because I use the Torque android app paired thru Bluetooth with the ELM327 to monitor the cars sensors (no OEM tachometer) I can see the ICE running & RPM at all most all times except during stops at lights when the ICE shuts off to conserve gas.
If I wanted to maintain the MPG vs HP, i'd prob leave the intake manifold and throttle body as is....but since HP is more what I am looking for with MPG to spare....guess I won't know unless I try. :)
JustDidIt is offline   Reply With Quote
Old 01-13-2013, 08:02 PM   #3
tooter
play every day
tooter's Avatar
That's the spirit.
If it doesn't work out you can always simply go back to stock.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
