#991 |
play every day
I combined the Simota intake tube with the BLOX velocity stack because the Simota is larger in diameter which matches the larger diameter of the Corolla throttle body throat...
![]() Now no adaptor coupling is needed, as everything is all the same size straight through from the velocity stack to the throttle body... ![]() ![]() Notice the throttle body?... you'd never know that was an 8 year old junkyard part. Stainless steel micro bead blasting makes the old casting look like it's brand new. I think I'll go for a ride now.
#992 |
![]() Drives: 02 Yaris 1.5 T-sport Join Date: Dec 2012
Glad to hear you got it running sweet!
cant wait for the dyno!
#993 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
That's awesome you got it all straightened out. I wanted to adjust the idle screw on mine, but it didn't bother me enough to go out of my way to take the time to do it. Now I kind of wish I had...however, I agree, the throttle response is AMAZING! My fiance, who used to have a Yaris, even commented on the difference it makes!
Can't wait to see what the dyno puts down for you!
#994 | ||
play every day
![]() I can't believe that it works so much better than the stock throttle body. Especially in low rpm response. You barely touch the pedal and the car is right up to speed. Haven't taken it on the freeway yet, but I'll do that tomorrow. It's all gassed up and ready to take mileage readings. Quote:
![]() Now the 1.8 throttle body matches the 1.8 manifold as well as the oversized SRI. |
#995 | |
play every day
#996 | |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
#997 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
No dude, THANK YOU!!! I am so happy you got it running good finally, and that there seems to be a noticeable difference. Looking at the two throttle bodies side by side, you would think there would have to be. The stock TB is so small!
Anyways, this has been a great thread to follow, and I know I can speak for the entire community when I say thanks for posting so often and clearly about the issues and wins you have been having. These threads help us all out. Again, congrats, and I can't wait to see what this sucker does on the dyno. Please post a vid with audio! I bet she screams! |
#998 |
![]() ![]() Drives: Gen 1 XB Join Date: Nov 2012
Staring at pic............................................... .................................................. .................................................. .................................................. .................................................. .................................................. ...........still staring at pic............................................... .................................................. .................................................. .................................................. .......damn nice.............................................. .................................................. .................................................. .................................................. .......still staring.
Why strive for a JDM BB, when you can promote the Scion badge? |
#999 | |
play every day
![]() From this experience I'm pretty certain that the chips don't even need to be swapped. The butterfly just needs to close farther so that the ECU can find the right idle. Because when I ran both chips, both had the same symptoms. Reducing the idle speed alone is what resolved all of the issues. So in the future... If anyone wants to install a part number 030 Corolla 1ZZ throttle body on their 1NZ engine, don't mess with the chips, and simply turn the idle down by backing out the little idle adjustment screw counterclockwise one turn using a 5/64th inch hex key... and everything should work just fine. I did quite a bit of driving today on the freeway and in traffic with shopping and running errands, and I'm so thoroughly pleased with how well the engine responds with the bigger throttle body. It behaves like a completely different car!
#1000 | |
#1001 |
play every day
Well... maybe.
![]() Although hybrids use an Atkinson cycle engine which is quite different from regular Otto cycle engines. Atkinsons fire once per revolution, whereas Ottos fire once for every two revolutions. So this means that your ECU likely has totally different running parameters seeing as the engine spins the generator to charge the batteries. That completely different style of intake manifold is the tipoff. It looks like it is made to operate optimally in a very narrow rpm range. The bolt spacings are: 67mm 71mm 76mm They'll also need to be in the right orientation and not flipped over. So if the 76.. is on the right and in a vertical position, the top left will be 67mm and the bottom left will be 71mm like this... ![]() See if they match yours.
#1002 |
I think you're confusing it with a 2 stroke. Atkinson cycle is the same as Ottos. The only difference is that Atkinson has a shorter compression stroke than power stroke. On the Prius, this is achieved through intake cam timing and duration. The intake valve is held open much longer allowing some of the intake charge to be pushed back on the compression stroke reducing the energy required to compress the intake charge. This in turn rises the efficiency of the engine by effectively making the power stroke longer extracting more energy.
#1003 | |
play every day
You're right. Hybrid engines acheive the Atkinson effect with valve timing. Found this by searching How does a Prius hybrid engine work: "Its engine only runs at an efficient speed and load - In order to reduce emissions, the Prius can accelerate to a speed of about 15 mph (24 kph) before switching on the gasoline engine. The engine only starts once the vehicle has passed a certain speed. And once the engine starts, it operates in a narrow speed band." The bottom line is that installing a different throttle body on the engine might impair the optimum performance in that very narrowly tuned rpm range. This explains why they use that weird intake manifold. |
#1004 | |
Because I use the Torque android app paired thru Bluetooth with the ELM327 to monitor the cars sensors (no OEM tachometer) I can see the ICE running & RPM at all most all times except during stops at lights when the ICE shuts off to conserve gas. If I wanted to maintain the MPG vs HP, i'd prob leave the intake manifold and throttle body as is....but since HP is more what I am looking for with MPG to spare....guess I won't know unless I try. :) |
#1005 | |
play every day
![]() If it doesn't work out you can always simply go back to stock. |
#1006 |
Ya, I get snickered at often over at the PriusChat - buncha eco modders.. But its my car, I'll do what i want. I read up on the Bonneville Salt Flats Prius
![]() When they set the 'record' in the G2 Prius, they did it by swapping the 1NZ-FXE for the 1.5L 1NZ-FE otto cycle motor swap from echo, modified the intake routing (but used the 1NZ-FXE intake manifold - no room for the 1NZ-FE manifold because of the Invertor and MG1&MG2 configuration under the hood), JDM TRD ECU, inverter upgrade (550V from 500V), final gear changes, transmission cooling system, custom 1-off suspension, larger front diameter tires and custom exhaust. |
#1007 | |
What was the record, and how long was the course?
#1008 | |||
http://www.theautochannel.com/news/2...21/308572.html This was all done in 2004... so prob not much of a record anymore. Jetta set one this past year at 186mph but using a 1.4L with a turbo. Class - H/PS. The class is for production cars with engines of less than 1.5 liters that use forced induction. So not in the same class as the Prius... Quote:
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
