Old 01-12-2013, 09:31 AM   #10
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by tooter View Post
Well... maybe.
Although hybrids use an Atkinson cycle engine which is quite different from regular Otto cycle engines. Atkinsons fire once per revolution, whereas Ottos fire once for every two revolutions.
I think you're confusing it with a 2 stroke. Atkinson cycle is the same as Ottos. The only difference is that Atkinson has a shorter compression stroke than power stroke. On the Prius, this is achieved through intake cam timing and duration. The intake valve is held open much longer allowing some of the intake charge to be pushed back on the compression stroke reducing the energy required to compress the intake charge. This in turn rises the efficiency of the engine by effectively making the power stroke longer extracting more energy.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
