Old 01-13-2013, 05:58 PM   #10
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Originally Posted by tooter View Post
In order to reduce emissions, the Prius can accelerate to a speed of about 15 mph (24 kph) before switching on the gasoline engine. The engine only starts once the vehicle has passed a certain speed. And once the engine starts, it operates in a narrow speed band."
Currently I have enabled the EV mode hack which is standard on the EU and JDM Gen2 Prius This allows the prius to use the Electric motor only up to 34mph as long as the there isn't much demand for power. If I romp on the gas from the start - during heavy acceleration or hills both the ICE and MG2 move the car along.
Because I use the Torque android app paired thru Bluetooth with the ELM327 to monitor the cars sensors (no OEM tachometer) I can see the ICE running & RPM at all most all times except during stops at lights when the ICE shuts off to conserve gas.
The bottom line is that installing a different throttle body on the engine might impair the optimum performance in that very narrowly tuned rpm range.
This explains why they use that weird intake manifold.
If I wanted to maintain the MPG vs HP, i'd prob leave the intake manifold and throttle body as is....but since HP is more what I am looking for with MPG to spare....guess I won't know unless I try. :)
JustDidIt is offline   Reply With Quote
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
