#1 | |||||
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
![]() Quote:
![]() Quote:
![]() I especially like the BLOX dry filter as it has no oil issues. It perfectly seals the stack and removes instantly and easily for cleaning. Quote:
![]() This is because the tube the MAF is in is 2.25". You can see the reduction in diameter takes place in front of the MAF. Quote:
...as long as it reduces down to the proper 2.25 diameter where the air flows over the MAF. Since I'm here, I took a whack at grinding one of the runner entrances. The amount of weld I can remove is limited so as not to weaken the manifold, but at least I was successful in removing the protruding weld swirls as I'm sure they cause turbulence right at the critical point of entry. I was also able to open up the entrance a bit wider for a freer flow. ![]() This is before for contrast...
![]() ![]() Drives: Gen 1 XB Join Date: Nov 2012
Damn that Blox venturi is sexy. Smoooooooth flow!!!
Why strive for a JDM BB, when you can promote the Scion badge? |
play every day
2ZR swap. DO IT! Ask how!
So if the air all has to flow through the narrower section, doesn't it negate the larger diameters in front of/behind the MAF? I haven't done fluid mechanics yet, so I'm just going off what I've read/heard/seen.
#5 | |
play every day
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Any progress?
play every day
Yes.
![]() We arrived at a really neato design and I should have the new throttle body base plates any day now. The CNC machinists have been very busy so they fit me in when they have the time because my parts are such small runs. I can't wait to get them and will post pics as soon as they're done. This tooter is going to be a very strange one!
#8 | |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
#9 | |
play every day
I still stock and sell them with the complete manifolds and with the flanges in the Build-Your-Own-Manifold kits. But I'm totally into experimenting now... ![]() ![]() ...with a completely new scratch built plenum for the tooter. So it needs a radically different design throttle body base. |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
