Old 04-12-2007, 06:41 PM   #1
AlphaFox
AlphaFox's Avatar
Drives: 07' Yaris Liftback - silver
what kind of MPG increases are you seeing running at 50 or 60 psi? (up from stock)
AlphaFox is offline
Old 04-12-2007, 07:22 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
There is a "thingy" in your glove box called an Owner's Manual, comes "free" with the Yaris. Try opening it up. Theres lots of words in there and "stuff"
SPONSORED BY
brickhardmeat is offline
Old 04-12-2007, 07:41 PM   #3
BailOut
Steals terrorist's lunch
BailOut's Avatar
That's a hard one to answer because your driving style really plays into it. If you're a regular, everyday kind of driver then you will see maybe 0.5 - 2 MPG, just because it's easier for your engine to make the car roll if it doesn't have to fight the tires so much.
If you hypermile then the benefits shoot through the roof. For example, on my commute home there's a section of the mountain road that is just very slightly downhill for almost a mile. I used to have to use fuel in this area but with the tires at 60 PSI I can turn off the engine (and then go back to Ignition II to keep PS/PB for a while) and coast that entire section without dropping speed. I can pull a similar stunt for about another mile at the bottom of the mountain after going through the clover leaf on-ramp. I can use it twice again in my subdivision for another half mile each time after accelerating to 40 in a 45 MPH zone. I can stealth coast from the main subdivision road through 4 90-degree turns and right up my driveway and into my garage.
- Brian
Share the Road
BailOut is offline
Old 04-12-2007, 07:48 PM   #4
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Not to bring you guys down, but, this is a really bad idea. Max pressure is called that for a reason. You do know your tires heat up with highway speeds so even putting them at 44 means they are running far higher than that with sustained speed. Setting them at 60PSI means they could go over 70 with summer heat and fast driving. Blow-out time!
PetersRedYaris is offline
Old 04-12-2007, 07:56 PM   #5
BailOut
BailOut's Avatar
Back in the 1970's you would have been right, Peter. However, since that time consumer tires have been steel belted which prevents this from happening. The worst that could happen on just about any modern tire is some uneven and/or early tread wear.
I commute over a mountain every day in snow or sun at 60 PSI without issue. As I mentioned earlier a fellow hypermiler who does a lot of highway driving just hit 85,000 miles on his RE92s, which is literally impossible at 32 PSI. We are just 2 out of a pool of folks that have been running at 60 PSI for quite some time now not only without issue but with several tangible benefits.
- Brian
Share the Road
BailOut is offline
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 07:29 AM
Tire Pressure and Gas Economy KittenRD General Yaris / Vitz Discussion 11 01-25-2007 11:54 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 01:37 PM
stock tire pressure... argylesocks Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-16-2006 01:28 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
