![]() ![]() ![]() Drives: 07' Yaris Liftback - silver Join Date: May 2006
what kind of MPG increases are you seeing running at 50 or 60 psi? (up from stock)
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
There is a "thingy" in your glove box called an Owner's Manual, comes "free" with the Yaris. Try opening it up. Theres lots of words in there and "stuff"
SPONSORED BY
#3 | |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
If you hypermile then the benefits shoot through the roof. For example, on my commute home there's a section of the mountain road that is just very slightly downhill for almost a mile. I used to have to use fuel in this area but with the tires at 60 PSI I can turn off the engine (and then go back to Ignition II to keep PS/PB for a while) and coast that entire section without dropping speed. I can pull a similar stunt for about another mile at the bottom of the mountain after going through the clover leaf on-ramp. I can use it twice again in my subdivision for another half mile each time after accelerating to 40 in a 45 MPH zone. I can stealth coast from the main subdivision road through 4 90-degree turns and right up my driveway and into my garage.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
Not to bring you guys down, but, this is a really bad idea. Max pressure is called that for a reason. You do know your tires heat up with highway speeds so even putting them at 44 means they are running far higher than that with sustained speed. Setting them at 60PSI means they could go over 70 with summer heat and fast driving. Blow-out time!
#5 | |
I commute over a mountain every day in snow or sun at 60 PSI without issue. As I mentioned earlier a fellow hypermiler who does a lot of highway driving just hit 85,000 miles on his RE92s, which is literally impossible at 32 PSI. We are just 2 out of a pool of folks that have been running at 60 PSI for quite some time now not only without issue but with several tangible benefits.
| Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 03-16-2011 07:29 AM |
| Tire Pressure and Gas Economy | KittenRD | General Yaris / Vitz Discussion | 11 | 01-25-2007 11:54 PM |
| Tire Pressure | slvryaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 11-05-2006 01:37 PM |
| stock tire pressure... | argylesocks | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 09-16-2006 01:28 AM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
