Originally Posted by DarkShadowFox
i think i will use the LE eco corolla because it has 140 hp
My recollection is that the Corolla LE ECO only came with a CVT; I could be wrong if you look back to earlier years though.. If that suits what you want then you're aces - and may have the first CVT swapped Yaris? However, if you want to run with the Yaris AT or MT then you will run into difficulties. Pulling the engine from a Corolla LE ECO will get you a 2ZR-FAE, but just mind the fact that you'll need an iM (or other -FAE based) ECM to run stock with the AT or MT transmissions.
Of course, if you're mixing and matching engines and transmissions and not using a stock setup then you're well out of my league and diving into new territory.
-- Adam
