#27 |
Quick test the RED wire that goes to the fog lights put it to the POSITIVE terminal of the Battery
Fog lights should come on . NO wrong wire or bulbs are blown . Just watched your Video the RED wire from the Fog Lights (does it go to the fog lights) Goes too the Pin 1 & 2 wires in the under bonnet relay box You should only have the one wire that goes to the fog lights which connects to pin 1 and 2 and the fog light earth wire to deal with under the bonnet . The 3 wires you have togeather should be running to the switch if you are useing the switch supplied which you appear to be and the switch wireing is all done inside the car by removeing the cover around the steering colum .READ INSTRUCTIONS IN PDF . Attached again . the rest is rubbish , |
| Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) | Lafiro | Cosmetic Modifications (Exterior/Interior) | 2 | 06-12-2009 03:56 PM |
| Disabled DRLs and Factory fog lights | DARKYARIS | DIY / Maintenance / Service | 21 | 05-01-2007 05:32 PM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-02-2006 11:38 PM |
