#19 | |
![]() Drives: toyota yaris 1.0 t3 2004 Join Date: Feb 2013
you can post on the thread above. cheers ![]()
#20 |
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
This is on my hit list.Will do it next, i am on 93 000 Ks Thanks for the heads up mate!
I've changed the drive belt, manual transmission fluid. This is next. :) anything else we should service or replace? |
#21 |
I am still trying to understand how you can tell from the way the car runs as to whether this needs changing, cleaning or what. Sounds like to me this generally will either be fine or just need cleaning, but I am just not sure how to tell it needs either from how the car runs.
Thanks, |
#22 |
" My engine idles rough and oscillates badly when either in drive or a/c on in drive; when in neutral, it idles smoothly. I would like to know before the check engine light comes on. "
Our '08 sedan has done this since new . Replaced the P.C.V. at around 20,000 miles and no difference . Still idles rough when in gear at stops or idling . Fine when in neutral or park . The car now close to 58,000 miles . |
#23 | |
Did your PCV really need replacing at that point?
#24 |
Thought it might help with the rough idle . No difference . Not all that expensive or difficult to replace .
#25 |
Just cleaned mine, it was a little clogged. Runs smoother now.
#26 |
Checked mine. Have about 90500 miles on the odometer. Wasn't clogged, rattled freely. Cleaned it off anyway and put it back in.
#27 |
Thinking about checking mine tomorrow as well. Must be a fad.
#28 |
lol. One of the bigger things right now on YW, I guess. Since everyone was talking about theirs, and since it's such an easy thing to check and clean, I just thought, "might as well." Also wanted to see the condition of mine after 90,500 miles.
| PCV valve question | window_lee | DIY / Maintenance / Service | 31 | 10-22-2014 04:05 PM |
| Valve Noise | barryware | DIY / Maintenance / Service | 25 | 02-13-2013 02:39 PM |
| Two different PCV valve Part#s for Yaris? | auxmike | DIY / Maintenance / Service | 6 | 03-18-2011 08:55 AM |
| PVC valve routine? | N9QGS | DIY / Maintenance / Service | 13 | 05-26-2009 07:32 PM |
| 2007 Yaris LB - Valve Adjustments | Pavel Olavich | DIY / Maintenance / Service | 3 | 03-30-2007 05:34 PM |
