![]() Drives: 08 4dr Hatchback Join Date: Aug 2010
Spring, wheel and tire fitment
Yes, I did some search not to start another thread but couldn't find my answer... So here it is; I want a slight drop on my 2008 and think the TRD springs would do it without compromising on comfort.
1. Am I right in thinking that way? Is there a better and/or cheaper alternative. 2. With 16 x 7 wheels and 205/50/16, will there be some rubbing? 3. If yes, what is the larger size 15" or 16" wheel combo recommended not to rub? Thanks Dan |
#2 | |
if ur car is higher milage I recommend new struts with springs. just my 2 cents on this |
Sorry, forgot to mention; rims are 40 offset (Konig Feather 16 x 7). 250/50/16 are now mounted on these but they are quite worn out so I have to change them. I was looking to use the same wheels but may I go back to 15 x 6 or 15 x 6.5 wheels to get a more bulging tire
#4 | |
With 205/50/16 there is some rubber exceeding the rim and you get some protection against wheel scraping on curbs. I wonder what will happen with 195/50/16; is the wheel wider than the tire?
the stretch look...not by much on a 7 inch rim may actually be flash with the rim
| Wheel, tire, offset, and lowering spring advice. | PDFileKyle | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 02-24-2013 05:53 PM |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
