Old 01-22-2014, 09:03 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Originally Posted by ddeschen View Post
Yes, I did some search not to start another thread but couldn't find my answer... So here it is; I want a slight drop on my 2008 and think the TRD springs would do it without compromising on comfort.
1. Am I right in thinking that way? Is there a better and/or cheaper alternative.
2. With 16 x 7 wheels and 205/50/16, will there be some rubbing?
3. If yes, what is the larger size 15" or 16" wheel combo recommended not to rub?
Thanks
Dan
Proper size would be 195 50 16 as for rub .....offset and width of rim can make or brake a set up u can run lots of diffrent combinations but as a rule u should stick to what is original yaris stock offset is 45 to 50 on se 16 inch rims so if u go 40 ull be fine as for tire find one that is with in 3% of original size.....im running 195 55 15 42 offset and 1.8 inch drop with no problems at all ....trd drop if not mistaken is only .5 front and 1.5 rear .
if ur car is higher milage I recommend new struts with springs.
just my 2 cents on this
Wheel, tire, offset, and lowering spring advice. PDFileKyle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-24-2013 05:53 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
