Old 01-23-2014, 08:44 PM   #5
ddeschen
ddeschen's Avatar
Drives: 08 4dr Hatchback
Originally Posted by Exiwolfman View Post
If ur getting new tires for the 16s go with either 195 50 or 205 45 I find that if u go to wide car will wonder ....stock SE 16 rim tire size is 195 50 16 with that size and 40 offset u should be fine no rub when u lower ur yaris.
With 205/50/16 there is some rubber exceeding the rim and you get some protection against wheel scraping on curbs. I wonder what will happen with 195/50/16; is the wheel wider than the tire?
ddeschen is offline   Reply With Quote
Wheel, tire, offset, and lowering spring advice. PDFileKyle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-24-2013 05:53 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
