![]() ![]() Drives: 2005 Echo Rs Join Date: Sep 2010
I put in a fidanza flywheel in my echo this winter.
Replace the clutch housing, clutch and throw-out bearing. I pulled the drive shafts ; not that hard when you figure out where to pry from. I had to lower the sub-frame; I tried, but couldn't find a way around that. I used a cut up office chair and car jack as my transmission jack. Not ideal but it worked. I used the front strut bar and garage rafters as an engine hoist. Again crude, but it worked. |
| clutch install & flywheel questions So Cal | xb visitor | Performance Modifications | 3 | 11-04-2013 10:43 AM |
| Questions for new flywheel and clutch | mrbond | Performance Modifications | 11 | 07-11-2013 07:17 AM |
| Flywheel question-1nz conversion-2003 Model | Echo56 | DIY / Maintenance / Service | 0 | 05-21-2013 10:42 PM |
| Cp Pistons, Pauter rods , greddy, fidanza and other for 1NZ-FE!!! | Giupo | Items for Sale by private party | 11 | 08-25-2009 02:57 PM |
| lightweight flywheel from fidanza | dngz | Performance Modifications | 34 | 02-03-2009 11:02 PM |
