Old 05-14-2016, 01:50 PM   #18
CoryM
Drives: 2009 5-door, 5-speed
Originally Posted by invader166 View Post
Hmmm...your OP states that you have Tokico blues installed? I've heard they are a pretty stiff shock. Why not try some softer shocks with the front bar? That way, maybe you can load and unload your tires at a faster rate and be able to further increase your tire contact with the road.
Just another idea, but like you stated above. No way to really find out without some serious tests, and proper math.
I could definitely do better in the shock department. I'm not sure what the blues are intended for, but stock springs is not it. I only got them because I needed something to replace a damaged OE strut. The Yaris only gets new parts when it *needs* them. The whole point of me driving the economical car is to spend less on it so I can spend more on faster cars . This is also why I've stayed in HS as it reduces the temptation to buy stuff for the little car.
Cheers.
budget B Spec rally build slowly coming along 07dirtyaris Tracking, Racing, Auto-X Forum 8 08-15-2016 04:21 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Turbo build - stage 1:D abstractmethod Forced Induction Forum 21 03-13-2014 08:04 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
