Old 10-01-2017, 12:07 AM   #28
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by edmscan View Post
I believe the first year where you saw "immobilized" Yaris' in Canada was in 2008. I have an RS model here in Canada and the immobilizer was not an option in 2007.
You can tell if you have an immobilized car as your ignition will have a plastic black ring around it if you have it, and a silver ignition with NO plastic ring if you have a normal vehicle.
Canadian Yaris does not come with the security system the other models have. Even the ones with immobilize, so it will not beep. I'm fine with that.
My Toyota Echo had the RS3200 security system option installed and it beeps locking and unlocking the doors.
Disable beep when driver door open and key in ignition fmicle DIY / Maintenance / Service 7 05-03-2018 05:30 PM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
How do you make keyless beep on unlock and unlocking the car. marcus General Yaris / Vitz Discussion 7 04-17-2007 09:53 AM
Annoying beep clayky General Yaris / Vitz Discussion 4 01-30-2007 03:34 AM
How to disable the beep? (ASAP) Rahxephon General Yaris / Vitz Discussion 16 06-05-2006 05:03 PM
