![]() Drives: 2015 Toyota Yaris MT Join Date: Aug 2021
Spring, shocks/struts, and rear sway bar compatibility?
I have a 2015 Toyota Yaris L (2-door hatchback manual transmission)
Are the following parts compatible? They're all listed for 07-11 model years but from my research it seems not much has changed suspension-wise between the older and newer hatchbacks. Bilstein B8 front strut (22-236296) Bilstein B8 rear shock (19-236315) Tein S Tech lowering springs (SKC10-AUB00) TRD rear sway bar (PTR1152071) |
I found the answer in this post thanks to mitch9521
The appetite for modding this platform really started its demise sometime in 2010, two years into the gen2 facelift. Nobody does gen3 product development, nor have any companies that supported the gen2 with aftermarket products even bothered to fitment test on the gen3 and update their compatibility databases.
It's pretty much come down to someone taking an educated guess, taking the plunge, and then word gets spread like it did in this case. In a nutshell, engine, drivetrain, brakes, suspension all the same gen2 to gen3.
#4 | |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Its too bad cause these cars are super light and tossable, they're considerably lighter than Honda Fits and those have lots of aftermarket support.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
I bought my Bilstein B8s from RockAuto.com, and they're cheaper compare to that eBay seller, but you'd have to pay for shipping. Ironically, I bought the Tein's lowering springs from eBay, for only $120.
#6 | ||
Can't wait to see the pics. I haven't had the chance to do it, but I'll be trimming the bump stop by half an inch. I felt a slight bottom out when I hit a bump going 70MPH.
Does anyone know the spring rates for the Megan Racing springs? According to the Tein website, the S.Tech springs that I have are 3 kgf/mm on the front and 3.5 kgf/mm on the rear. https://www.tein.com/tech_info/l70.html |
#9 | |
Just to put it out for everyone without having to click at the links provided, the Tein S.Tech are 170lbs/in in the front and 200lbs/in in the rear, while the Megan Racing Springs are 126lbs/in and 140lbs/in respectively. |
![]() Drives: '18 Yaris SE Join Date: Oct 2022
So basically, if I were to order springs or coilovers for an older gen, it should fit my '18 Yaris? Because I cannot find anything that goes with my year anywhere.
Correct.
| Tags |
| bilstein, compatible, lowering, tein, trd |
| Rear Sway bar, worth it ? Other options? | road_junky | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 02-06-2014 10:08 AM |
| WTB: Weapon R Dragon Intake and TRD rear sway bar. | TerenceCruz | Willing to Buy by private party | 2 | 07-28-2013 05:13 PM |
| Which rear sway bar? | IsLNdbOi | Performance Modifications | 46 | 11-05-2009 06:07 AM |
| Is the TRD rear sway bar a worthwhile upgrade? | YellowJolt | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 07-15-2009 08:07 AM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
