Old 05-09-2010, 01:28 AM   #19
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Originally Posted by enviri View Post
i have a '10 and my alarm beeps....70% of the time.
I have a '10 also and my alarm beeps.... 0% of the time.
Old 06-05-2010, 06:52 AM   #20
yaris2010RS
yaris2010RS's Avatar
my '10 never beeps but i cant make my alarm go off.....
Old 04-12-2013, 12:49 AM   #21
misterwolfe
What is a clutch?
Drives: 2007 Yaris HB
Send a message via AIM to misterwolfe
My 2007 HB with the power package doesn't beep, but my 2012 Corolla S beeps. Neither have break in alarms. It's just cost cutting.
Also, my 2012 Corolla S has an immobilizer, maybe that's the difference?
misterwolfe is offline   Reply With Quote
Old 04-12-2013, 01:41 AM   #22
YarisSedan
Drives: 08 Yaris Sedan
I have a 08 and my car beeps.
Old 04-12-2013, 03:13 PM   #23
misterwolfe
What is a clutch?
I contacted Toyota, and apparently the beep has something to do with the immobilizer.
A Yaris with an immobilizer will beep, but one without the immobilizer will not. I am in Canada right now, and the Yaris is very popular here. I hear them beep quite often, even the older models back to 2006.
Interestingly enough, I think that applies to their other cars too as my 2012 Corolla S has an immobilizer, and it does, beep.
Old 04-13-2013, 03:36 AM   #24
edmscan
edmscan's Avatar
Drives: 2020 Corolla
I believe the first year where you saw "immobilized" Yaris' in Canada was in 2008. I have an RS model here in Canada and the immobilizer was not an option in 2007.
You can tell if you have an immobilized car as your ignition will have a plastic black ring around it if you have it, and a silver ignition with NO plastic ring if you have a normal vehicle.
edmscan is offline   Reply With Quote
Old 04-13-2013, 09:16 PM   #25
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
That is of course if you have the original keys. If you don't who knows what you will have. If you are like me and made a habit of losing keys, you will have random keys absolutely everywhere and carry 2 or 3 around with you at all times.
Colin Chapman disciple
Old 04-13-2013, 09:27 PM   #26
edmscan
edmscan's Avatar
www.yarisworld.com/forums/showthread.php?t=37095
As per this thread .. and CTScott, "No Black ring .. no immobilizer"
It is NOT really about the keys, but rather if your car is so equipped.
Old 09-30-2017, 03:47 PM   #27
cerberii
Drives: 2005 Yaris
I believe this can be programmed in the ECU's theft deterrant options. It clearly shows in the manual that this is an option that can be programmed with a smart meter. It CAN beep, now if only someone would writeup about how to do that?
cerberii is offline   Reply With Quote
Old 10-01-2017, 12:07 AM   #28
Canadian Yaris does not come with the security system the other models have. Even the ones with immobilize, so it will not beep. I'm fine with that.
My Toyota Echo had the RS3200 security system option installed and it beeps locking and unlocking the doors.
Sent from my SM-G930W8 using Tapatalk
Disable beep when driver door open and key in ignition fmicle DIY / Maintenance / Service 7 05-03-2018 05:30 PM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
How do you make keyless beep on unlock and unlocking the car. marcus General Yaris / Vitz Discussion 7 04-17-2007 09:53 AM
Annoying beep clayky General Yaris / Vitz Discussion 4 01-30-2007 03:34 AM
How to disable the beep? (ASAP) Rahxephon General Yaris / Vitz Discussion 16 06-05-2006 05:03 PM
