Old 09-04-2012, 02:37 AM   #19
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
Originally Posted by ruvios View Post
hey guys. what about wheels on 205/40/17? what is the best thing for this kind of tire?
planning to get Tein S-Tech with a 1.5 drop. what do you think? need a 1 to a tight 1 finger gap.
thanks.
i got the same tire as you want (205/40/17). mine is Nitto tires (Japan). I got a problem because my G-games wheel has +40 offset, the rear tires are rubbing on the fender when Im fully loaded even in a small uneven surface...Im planning to change my wheels sooner or later
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 09-04-2012, 02:40 AM   #20
Rubbing with +40 offset? Only time I started rubbing was when I had 17x7.5, ET28 with 205/40/17 tires. Rolled the rear fenders, and rubbing went away. Now I'm on 17x8, ET32 in the back, and no rubbing.
Old 09-04-2012, 03:50 AM   #21
xtremist
xtremist's Avatar
ya, that's why i need to check again, the funny thing is that Im not the one having this same prob. one of my friend also having the same specs of the tire and the most of the rubbing is only on the right rear tire. he just put a stopper on his spring and the rubbing is gone during uneven surface.
Ciao !!!
Old 09-04-2012, 07:33 AM   #22
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
That is odd that you are rubbing on that set up. On 8" wide wheel, +20 on 195s I barely rubbed. I was pm 15s but my fender gap is non existant so I should be rubbing a lot more than you if you're rubbing already.
I did have the same thing you describe where only my rear driver tire rubbed which was caused by the seating postion combined with the lower spring rate in the rear.
Try rolling/pulling the fenders
Old 09-04-2012, 09:56 AM   #23
xtremist
xtremist's Avatar
thanks bro...
Ciao !!!
Old 09-04-2012, 02:06 PM   #24
Mind taking some closer pics of your wheel/tire and fender? Shouldn't be rubbing too badly (if at all) with +40 unless your rims are super wide.
Old 09-09-2013, 08:05 PM   #25
Mz3oh5
Mz3oh5's Avatar
Drives: 13' HB
Y does my car lag when I turn fast corners? Will my lowering springs have any affect once I get them installed? Any advice?
--Isabella
Mz3oh5 is offline   Reply With Quote
Old 09-10-2013, 03:55 AM   #26
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Because your have a sub woofer at the back. That's why, IMO.
The springs will improve the handling.
Old 09-10-2013, 09:36 AM   #27
1.5
Form>Function
1.5's Avatar
what do you mean by lag can you expound on this?
Old 09-11-2013, 01:29 PM   #28
Mz3oh5
Mz3oh5's Avatar
Drives: 13' HB
Junorico24 thank your for your opinion, 1.5 (located in Tampa) I like your FB page maybe because I was born & raised in Miami :)
It drifts a little on a side like on sharp right turns. I have to break continuously before I turn instead of turning and keeping my momentum. Will a rear sway bar make any improvements?
--Isabella
Old 09-11-2013, 01:54 PM   #29
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
Stiffer springs would help some, but a sway bar would help a LOT.
D&D is offline   Reply With Quote
Old 09-11-2013, 02:41 PM   #30
1.5
Form>Function
1.5's Avatar
yes and thank you
this ^^ and dampers other torsion beams like sway/room bars/x braces/under body bracing/tires/wider wheel base from spacers... might be more too, lowering the car will lower the center of gravity and reduce body roll too
Old 09-11-2013, 03:30 PM   #31
Mz3oh5
Mz3oh5's Avatar
Drives: 13' HB
THANK YOU ALL FOR YOUR ADVICE. I feel better communicating with individuals who understand & drive my car.
I should stop driving fast, but I cant help it. I think im going to start with installing a TRD Rear Sway Bar which should be easy considering it has 4 bolts. I finally found a place who can install my TEIN Lowering Springs if anyone is interested I can show you a picture of how my car looks like before & after (in the future).
**BTW dont call Toyota dealership to install lowering springs they quoted me $900 & I also called a Tire & Auto Centers they quoted $1,000 & they tried to talk me out of it saying it will mess up my suspension .... really, then y do people still do it hahaha. I trust Toyota dealership than any other new establishment, but since when does lowering your car ever come out to $1,000 (I can save that money to do a paint job) ! Its usually $300-$600
--Isabella
Old 09-11-2013, 05:50 PM   #32
1.5
Form>Function
1.5's Avatar
Do it yourself it is not that hard and costs almost no money
Old 09-26-2013, 06:08 PM   #33
freshvitz
Drives: 2012 Yaris
Dealer ship will charge $$$ due to the fact that they have higher overhead cost. Besides, it's just springs. You can probably do it on your own if you have the proper tools. What made you go with Teins? Add some chassis parts and you'll have less body roll and it'll help a small car like a Yaris.
freshvitz is offline   Reply With Quote
Old 09-26-2013, 06:09 PM   #34
freshvitz
Drives: 2012 Yaris
Originally Posted by Betrivent View Post
With that size wheel, you can do almost anything to it to drop it. Cheapest option would probably be Tanabe NF210s. However, Tanabe springs do not last very long - they rust easily.
Or you can get some springs from Garm at Micro Image. He has some decently aggresive ones for under 200 I believe. HE has them made to order.
Cheapest or inexpensive? Tanane makes decent products but any product in harsh conditions will not last. Ride wise, Tanabe springs will not sag over time like other brands.
Old 09-26-2013, 06:14 PM   #35
Our Micro Image springs don't sag either, just to be clear.
Old 09-30-2013, 02:34 PM   #36
Neurotic Hapi Snak
Drives: 2011 Yaris 3dr
Would lowering my car help with body lift? At highway speeds, I can just feel the body lift up off the springs. With the boxy body and light weight, gusts of wind on the highway cause horrible body sway. At low speeds, the stock springs don't handle half bad, I just hate the sway at high speeds. And don't laugh, but a trailer hitch stiffens up the rear of the body.
Neurotic Hapi Snak is offline   Reply With Quote
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Want to lower 1" or so. hmmm piranha0522 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-25-2011 03:59 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
Lower Grill Replacement Idea (feeler) counterfiend Cosmetic Modifications (Exterior/Interior) 7 09-24-2009 08:40 PM
