Old 04-05-2009, 08:03 PM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
need help: foglight indicator - where are the wires?
Hi all. I'm looking for the wires that turn on the foglights symbol in the instrument panel (when lit, it's on the left of the speedometer). Where is it located and what wire is it? Thanks.
Old 04-05-2009, 08:42 PM   #2
1NZYaris1
1NZYaris1's Avatar
Here you Go , these should help, i hope
Old 04-05-2009, 09:01 PM   #3
Or, if you're installing aftermarket fogs without the stalk switch, you can fire the indicator directly by supplying 12V to the red wire on Pin 7 of the D2 connector on the combination meter.
Old 04-06-2009, 02:05 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Hi CTScott. Where is this D2 connector located? Yes, I have aftermarket fogs without stalk switch.
1NZYaris: Do I just need to add power to PIN3 and then the indicator will light up?
Old 04-06-2009, 02:48 AM   #5
1NZYaris1
1NZYaris1's Avatar
no you do not need to add power to pin 3 it is already there.
Old 04-06-2009, 08:22 AM   #6
If you pop the combination meter assembly off, it has two connectors D1 and D2. D1 is a 24 pin connector and D2 (the one you want) is a 16 pin connector.
By the way, I believe that Pin 3 on the stalk connector only works if you are using a fog light switch equipped stalk.
Old 04-06-2009, 11:31 PM   #7
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Hmmm. After reading the DIY ESUSE foglight install it looks like it's possible to use that stalk connector even if you don't have a stalk for fogs...? But what is pin 3 and pin 4 and how would you hook it up to the existing wires that came with the kit?
Old 04-06-2009, 11:37 PM   #8
1NZYaris1
1NZYaris1's Avatar
Not true at all , this is the way mine are wired, and they work great
Old 04-07-2009, 06:56 AM   #9
You installed the relay in the D46 position for that to work. The question is if his kit has the relay that installs there or if it has the external relay.
So, you are definitely correct that the stalk is not required, but the relay in that position, or the external relay wired through that position would be required.
The kit that I bought included an external relay, so I wired the indicator directly to the combination meter.
Here is the EWD for the fogs, which shows pin 3 and 4 on the upper left. The Fog light relay (at D46) is at the upper right. Its output feeds the fog lights and the combination meter indicator (center).
Old 04-07-2009, 06:01 PM   #10
1NZYaris1
1NZYaris1's Avatar
the diagrames above is for useing the switch supplied with the kit .
if you want to use the factory combo switch all you need is the relay
(factory , or aftermarket) to plug into factory position as per diagrames.
Old 04-10-2009, 10:06 AM   #11
mrbond
mrbond's Avatar
So, let's see if I understand this. If I wanted to use the factory stalk instead of the little button that goes into the console, then all I need to do is wire up the fog lights, put the wire into the fuse box in the engine bay, and then put the relay where it's supposed to go? So I wouldn't even need that extra wiring harness for the cabin? If so, that's fantastic.
- A Toyota Yaris
- A whut Yaris?
Old 04-10-2009, 10:34 AM   #12
mrbond
mrbond's Avatar
Oh thank God. I was reading all the DIYs for the cabin wiring and I was thinking to myself, there's gotta be a way simpler method to doing this. And there is, apparently :D
- A Toyota Yaris
- A whut Yaris?
Old 04-10-2009, 12:27 PM   #13
cyberfrogg
cyberfrogg's Avatar
Drives: Yaris Sedan S
How do you know I know if I have a fog light switch equipped stalk?
cyberfrogg is offline   Reply With Quote
Old 04-10-2009, 12:31 PM   #14
It will have a thin rotating band with the fog light symbol, besides the wide rotating end for the head and parking lights.
Old 04-10-2009, 12:35 PM   #15
cyberfrogg
cyberfrogg's Avatar
Ah then I guess I dont have it. =/
Im having trouble with my switch. The light indicator on the switch turns is on ALL the time except when I turn on my fogs. As soon as I turn them on, the little rectangle light on the switch turns off.. Its very annoying. I plugged in the wires into pin 3 and pin 4 of the D4 connector..
Old 04-10-2009, 12:40 PM   #16
Based on the wiring diagram, use of pins 3 and 4 requires the fog light switch equipped stalk. On a stalk without the fog switch, pins 3 to 4 should theoretically not be switched.
Old 04-10-2009, 12:43 PM   #17
cyberfrogg
cyberfrogg's Avatar
what do you mean they should theoretically not be switched? I'm sorry, I'm a noob at all this..
Could I just connect one of the wires to Pin 7 of the D2 connector on the combination meter like you said?
Old 04-10-2009, 12:56 PM   #18
Pins 3 and 4 are the input / output of the fog switch, so without the switch I am not sure whether they are left to float or what (I'd go out and put a meter on there to find out for sure, but I am in the middle of packing for vacation).
Actually, looking back up at what 1NZ posted, when you are using the console switch, it gets connected across pins 3 and 4, so it acts the same as the stalk switch. The key is that the OEM pin 3 wire is pulled from the stalk connector and the console fog light switch inserts between the OEM pin 3 wire and the connector. Pin 4 does not get touched or connected to on the connector.
If you just "tapped" your switch onto pins 3 and 4 then that would explain the issue you are having.
Speakers wires : how to identify + and - ? hystria In Car Entertainment + Electronics (audio / video / alarm) 23 05-27-2017 10:43 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Installing a remote starter without cutting factory wires? yaris08ce In Car Entertainment + Electronics (audio / video / alarm) 36 04-23-2009 08:59 PM
Ground Wires dngz Performance Modifications 8 11-26-2006 11:54 PM
Q about Routing wires to the engine compartment W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 10 11-01-2006 07:36 PM
