Old 11-13-2010, 12:14 PM   #1
Paris vvt-i
Drives: Yaris ts 1.5
hp vs psi
Well what do you think guys? I think that the right thing is talking about ''maximum horsepower'' for an engine component and not ''maximum psi''. I think that talking about an ammount of psi is pointless unless you are talking about a specific turbo.
what do you think?
Paris vvt-i is offline   Reply With Quote
Old 11-13-2010, 12:25 PM   #2
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
Yes you're right about the horsepower vs psi is based on the turbo size (among other factors). But the general rule on average is 1psi = 10hp
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 11-13-2010, 12:32 PM   #3
Paris vvt-i
Yesand i think that if someone is making 240hp with a T25 (20psi) it is the same thing for the engine if you had 240hp with a t28 (12psi). You have the same peak cylinder pressure during combustion if you make the same power. I think it is horsepower that breaks rods or cracks sleeves right?
Old 11-13-2010, 12:37 PM   #4
turboecho2005
No. Horsepower doesn't break rods or pistons. A bad tune or a hickup in a tune giving a spike in the air fuel causing it to run lean will blow your motor.
Old 11-13-2010, 12:45 PM   #5
Paris vvt-i
I do not completely agree with this. it is not only a good tune. the components of a specific engine have a limit in hp i think?
Old 11-13-2010, 01:09 PM   #6
turboecho2005
Limits... to some degree yes. I wouldn't run 20psi on stock . Longevity is more of a factor. It really depends on your hp goal.
Old 11-13-2010, 01:16 PM   #7
turboecho2005
Just to give you an idea. I am running 8.5psi with 11.1:1 compression on a hybrid gt28r turbo making over 250hp. Stock the motor makes 160hp. I could run 10psi but the egt is getting up there for continual use.
diff. tire size should mean put diff. psi right? ezhacker1 Fuel Economy Forum 10 01-14-2010 06:48 AM
Daily Driven Yaris @ 10 PSI ChinoCharles Forced Induction Forum 36 12-22-2009 11:29 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
