Old 09-14-2011, 09:37 PM   #1
patm
Drives: 2007 yaris sedan
rear right toe is out of spec? What to do?
Considering a 07 Yais sedan with no modifications, If the rear right toe is out of spec (and can't be adjusted) and if there is no problem with the beam can you say that the car was sent to the dealership out of alignment. Also, would this be considered a manufacturers defect. If it cant be adjusted how can you get the rear right toe to be within spec for a 4 wheel alignment.
patm is offline   Reply With Quote
Old 09-15-2011, 03:31 AM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
you could say that it is manufacturer defect if all the following is met:
-your the 1st and only owner of the car
-tire wear was abnormal before the first 15,000 miles,
then toyota will do an inspection under warranty and fix the issue or they will buy back your yaris.
BUT being an 07 I doubt any dealership will accept any fault and say its been in an accident or jumped a curb at some point in time.
-Derrick-
Old 09-15-2011, 07:54 AM   #3
A-Dingo-Ate-My-Baby
Drives: yaris
shims
A-Dingo-Ate-My-Baby is offline   Reply With Quote
What could cause the difference in rear toe? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 01-12-2010 12:48 PM
Rear toe adjustment...shims?? ozmdd Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-15-2009 10:32 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
