Old 09-26-2011, 03:01 PM   #1
cracked manifold
I guess if you throw 350 hp at it long enough, something is going to break.
Old 09-26-2011, 03:35 PM   #2
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Ehhh I feel sorry for you \Garm..... I hope this will not happen to me !
Funny thing I am not seeing carbon all around the manifold... are you sure it is cracked?
Old 09-26-2011, 04:40 PM   #3
The manifold was Jet-Hotted, that explains its overall color.
The carbon is exhaust gas coming out through the cracks. Trust me, it's got cracks in it!
Old 09-26-2011, 06:45 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Damn that sucks, but like you said...you use it and it will eventually give way...just the nature of the beast. At least it wasn't something like an output shaft or losing a gear.
Old 09-26-2011, 09:22 PM   #5
justjesus
justjesus's Avatar
Drives: 2008 Liftback
worse than I imagined!
Old 09-27-2011, 12:09 AM   #6
^ thanks for the advice today, Jesus.
Old 09-27-2011, 01:45 AM   #7
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
On the bright side, at least it wasn't the block or the head!
Is that cast? The cracked areas looks like it can be welded again... Unless you plan on replacing it altogether.
Old 09-27-2011, 10:02 AM   #8
Going to replace it. Art doesn't want to weld on Jet Hot (or any other coating), which I learned yesterday is wise advice.
Old 09-27-2011, 10:36 AM   #9
A-Dingo-Ate-My-Baby
Drives: yaris
haven't you seen 1fast 2furious ?
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 09-27-2011, 11:08 AM   #10
^ LOL, that movie actually did get me into tuner cars in the first place. And every time I hook up my laptop to data log, it reminds me of that.
Old 09-28-2011, 01:47 PM   #11
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Hmm looks like you were not putting out enough power. If you were running 400whp then it would not break. Due to the turbo encabulator rotation of the prefixed particle molecule, it built up enough fail to break the manifold.
Old 09-28-2011, 02:18 PM   #12
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
-Derrick-
Old 09-28-2011, 02:55 PM   #13
hehe
Old 09-28-2011, 03:22 PM   #14
fnkngrv
fnkngrv's Avatar
I bet if you would have used an upgraded Hemway during the process you would have been file. In this case since it is already broken you should upgrade to a better flux capacitor while you have it off.
Old 09-28-2011, 08:42 PM   #15
sickpuppy1
Drives: 2010 Yaris Sedan
umm I think its actually called a Henway, just to keep the record straight
Old 09-28-2011, 08:57 PM   #16
Could it be a lack of bracing and the weight of the turbo? I know the stock manifold has bracing to the block.
Old 09-29-2011, 12:06 AM   #17
^ could be; maybe we can fabricate some support for it.
Old 09-29-2011, 01:20 AM   #18
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Have Art build a custom manilfold to take-on that much boost. He obviously know his shit.
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
1ZZ-FE Manifold Swap Bluevitz-rs Performance Modifications 12 04-21-2010 09:00 AM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
Matrix 1.8 intake manifold dallas Performance Modifications 4 03-28-2009 01:42 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
