Old 05-27-2013, 04:23 PM   #1
dragoonmc
Drives: 07 hatchback
cracked CV joint help
So today I was changing my oil and noticed that there was something all over my drivers side wheel on the inner edge. I took the below picture.
I believe the CV boot is crocked or torn. What is the normal procedure for correcting this? A new boot or a new shaft?
dragoonmc is offline   Reply With Quote
Old 05-27-2013, 05:24 PM   #2
That does look like the boot has a crack or rip. People will sometimes just replace the boot (and there are split ones that install without removing the shaft, but they typically don't hold for long). With the work required to remove the shaft to replace the boot properly, your best best is to just replace the shaft assembly.
Old 05-27-2013, 05:33 PM   #3
auxmike
auxmike's Avatar
Blue struts, is the car lowered? Won't that change the angle and lead to rips then?
Old 05-27-2013, 08:14 PM   #4
dragoonmc
It is on eibach sportlines which does not drop the car very much at all. lowering the car will actually reduce the stress on the boots
Old 05-27-2013, 10:15 PM   #5
YarisSedan
Drives: 08 Yaris Sedan
New shaft typically 60 bucks at your local parts store. The time to change the boot only is not worth it and keep in mind if you change only the outer boot the inner boot rubber is dry and brittle and will tear likely soon after and you will end up having to take the axle out anyways to do the inner later on so might as well replace the entire unit.
Old 06-01-2013, 05:29 PM   #6
dragoonmc
Well I get the shaft and everything apart but did not notice the need for a slide hammer to get the shaft out before I torn into and it is the only car I have.
Any other way to get the drivers side shaft out of the transaxle?
Old 06-01-2013, 05:31 PM   #7
auxmike
auxmike's Avatar
Can you post some pics
Old 06-01-2013, 05:52 PM   #8
dragoonmc
Not really. The inner joint is tight to a portion of the transaxle case to the front and part of the bottom. almost the rest of the bottom and the back side is blocked by the crossmember.
The joint has 3 notches that are machined in to facilitate its removal but because of the surrounding things it can not be driven out by using a hammer
Old 06-01-2013, 05:56 PM   #9
auxmike
auxmike's Avatar
I had to remove both axels once on my 1997 Saturn 5 speed. They were tough to get out too. Bad thing is two days after the clutch job the trannny axel seals leaked! I didn't change those seals. Be careful..
Old 06-01-2013, 07:00 PM   #10
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
A CV boot can be replace without removing the shaft from the transmission.
The trick is to cut the boot, remove the outer joint, pack the joint with new grease, slide the boot on, line up the outer joint to the shaft, and pop it on. Then tighten clamps.
I've done thousands of boots in my previous career.
The outer takes more stress along the folds due to steering. The inner will outlast the car.
If the boot is still intact, the joint is still good.
Boots are 8 bux at rockauto.com
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 06-01-2013, 07:32 PM   #11
dragoonmc
I intend to replace the shaft and already have the shaft to do so. I also have to have this done by tomorrow night so I can get to work.
Old 06-02-2013, 11:04 AM   #12
Absolutely Red 12
Asshole
Have a trasmission seal handy.
Old 06-02-2013, 09:28 PM   #13
dragoonmc
Well its done. Ended up talking to a mechanic that suggested using a crowbar to get the shaft popped out. after some work at it I got that to work. it was in there much harder than I would have guessed. Now its all back together and I got the ATF change I was thinking about doing before this happened done.
It was about an inch long crack at one of the point ribs
click after cv joint replaced? bechdan DIY / Maintenance / Service 8 05-31-2013 05:16 PM
Cracked fog light lens! rossman DIY / Maintenance / Service 2 10-05-2012 03:04 PM
Driveshaft + CV Joint gordon_grech Willing to Buy by private party 1 01-12-2011 04:26 PM
Some dumb ass hit my car today and cracked the bumper.... YarisSedan Off-topic / Other Cars / Everything else Discussions 12 06-10-2010 02:44 PM
Ball Joint on Bottom Arm David Godfrey DIY / Maintenance / Service 1 04-18-2010 06:27 PM
