Old 08-02-2013, 04:37 PM   #1
Henry_mak16
Henry Mak
Drives: 2009 Toyota Yaris 2dr-hatchbk
What did you use to cut your bumpstop?
I'm getting into installing lowered springs, but I've read that I may have to cut my bumpstop. Do I need a power saw to cut that shyt? o.o And does anyone here ride without cut bumpstops (on lowered springs) without a problem on bumps? I'm still not even sure if I should cut them....
Henry_mak16 is offline   Reply With Quote
Old 08-02-2013, 04:39 PM   #2
7:34pm
Drives: 07 Yaris
No it's pretty much hardened rubber. You can use any hand sway with small teeth.
7:34pm is offline   Reply With Quote
Old 08-02-2013, 04:40 PM   #3
Henry_mak16
Henry Mak
If bottoming out doesn't have a big impact on the life span of my shocks, I don't think I would cut them.
Old 08-02-2013, 04:41 PM   #4
Henry_mak16
Henry Mak
Wow so those little guys absorb all the impact when a yaris bottoms out?
Old 08-02-2013, 04:51 PM   #5
racerb
I just installed TRD lowering spring on my car, I just cut the very bottom section off my bump stops, maybe 1/2" at the most. I used a 32 tooth hacksaw and just tried to cut as straight as possible. Running without bump stops can cause major internal damage to shocks/struts, so cutting them to allow just enough travel, will save your shocks!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 08-02-2013, 04:52 PM   #6
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
box cutter
Old 08-02-2013, 05:04 PM   #7
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I'm running H+R springs (1.5" drop) and didn't cut mine at all. no bottoming out in about 6 months so far.
Old 08-02-2013, 05:11 PM   #8
7:34pm
Drives: 07 Yaris
Put in an easy way to understand, they stop your struts from 'redlining'
I wouldn't cut them unless I have to try. Try it out for a few months without cutting them to see. If you hit them, cut off 1/4" and try again.
Old 08-02-2013, 05:54 PM   #9
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Lowered on NF210s, and didn't cut them... 2,684 miles later and I've yet to hit the bump stop at all.
Old 08-02-2013, 09:33 PM   #10
racerb
Just to clarify my reason for cutting my stops! Since my car is used for Auto-X and some Track Days, I will be more likely to cycle my suspension throughout it's full range of motion. A DD which is driven mostly on the open rode, will be less likely to encounter FIA curbing and high speed transitions, that we see regularly!!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 08-02-2013, 09:49 PM   #11
toad
toad's Avatar
Drives: street-legal go-kart
i just used my handy-dandy pocket knife! also, i followed the instructions on the DIY here for the tanabe df210 spring install(any type of spring should work with this DIY). i cut the bumpstops because when i read the reasons they made sense to me.
toad is offline   Reply With Quote
Old 08-02-2013, 10:48 PM   #12
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I cut them when I had my Tien S-techs on but had a few HARD bottom-outs entering/exiting parking lots. I went back to full factory stock with the MI springs and haven't had any strange behavior at the track yet.
Old 08-02-2013, 11:10 PM   #13
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
i just washed them of and bit it in half, works fine.
bump stops: to cut or not to cut? eric_edge DIY / Maintenance / Service 3 08-04-2011 08:35 PM
Tein Springs - Cut Bumpstop? 3dr SKurj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 05-10-2011 02:57 PM
Cut bumpstops IF using upgraded struts? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-08-2010 06:27 PM
Need help with Tein spring install... Smokey159 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 11-04-2008 06:39 PM
