Old 01-08-2014, 10:59 PM   #1
echo-francis
Drives: toyota echo
fidanza flywheel
I just receve my fidanza flywheel an will install it soon.
does some body has some tips? what to do or not to do? when installing it
I have a 2005 toyota echo.
echo-francis is offline   Reply With Quote
Old 01-09-2014, 08:00 PM   #2
Viperoni
Drives: 2005 Toyota Echo
-Install a new clutch at the same time
-Get new flywheel and pressure plate bolts
-Definietely get a load leveler for your engine hoist
-You may need to unbolt the subframe a bit to give you enough clearance to slide the tranny out of the way
-You probably won't have to, but getting the axles out of the tranny is a huge pain
2006 Saturn Ion Redline
Old 05-02-2014, 05:14 PM   #3
echo-francis
Drives: toyota echo
do you think a transmission jack can replace the engine hoist?
and is it really necessary to unbolt the subframe?
because where I will be to work on this I will have 1-2 friends and more then 1 transmission jack
Old 05-13-2014, 06:30 PM   #4
echo-francis
Drives: toyota echo
bump
Old 05-13-2014, 08:04 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
i pulled the power train to change my flywheel and clutch. makes the flywheel and clutch part easier.
Old 05-15-2014, 04:00 PM   #6
2005rs
Drives: 2005 Echo Rs
I put in a fidanza flywheel in my echo this winter.
Replace the clutch housing, clutch and throw-out bearing.
I pulled the drive shafts ; not that hard when you figure out where to pry from.
I had to lower the sub-frame; I tried, but couldn't find a way around that.
I used a cut up office chair and car jack as my transmission jack. Not ideal but it worked.
I used the front strut bar and garage rafters as an engine hoist. Again crude, but it worked.
2005rs is offline   Reply With Quote
clutch install & flywheel questions So Cal xb visitor Performance Modifications 3 11-04-2013 10:43 AM
Questions for new flywheel and clutch mrbond Performance Modifications 11 07-11-2013 07:17 AM
Flywheel question-1nz conversion-2003 Model Echo56 DIY / Maintenance / Service 0 05-21-2013 10:42 PM
Cp Pistons, Pauter rods , greddy, fidanza and other for 1NZ-FE!!! Giupo Items for Sale by private party 11 08-25-2009 02:57 PM
lightweight flywheel from fidanza dngz Performance Modifications 34 02-03-2009 11:02 PM
