Old 04-02-2015, 03:36 PM   #1
MountainMan
Drives: 2009 Yaris Hatch
205/50-15 Fitment Question
Hello, I am new to this forum and Yaris in general and I have a chance to get a set of Miata 5 spoke 15x6 wheels that have an offset of 40 and are wrapped with 205/50-15 rubber. I have looked at the stickied "Official YARIS Wheel & Tire Guide thread" and it says for an ET40 wheel you should normally max out at 195 wide.
But what I am wondering is if anyone has ran 205/50-15s on a Yaris hatch with stock suspension? What was your offset, will ET40 work? Any rubs; Big or Small? I plan on lowering the car in the near future and want to know if if they would pose an issue now and if I go to drop my car? or should I just put 195s on the rims and call it good?
Thanks for ya'lls input; I am used to muscle cars and jeeps with large wheelwells that I can easily make larger with a roller, hammer or cut off.
MountainMan is offline   Reply With Quote
Old 04-02-2015, 05:25 PM   #2
sheekeebut
Minimalist
Drives: 07 silver sedan
My feedback:
I ran coilovers 4k front springs and 3.1k rears, 1 1/2 inch lowered all around,15x6.5 38ET rims with 205/50R15. Street driving I did just fine, not a single rub, even when at full passenger capacity. Didn't care to try that on the track, though. You can see how much clearance I had in my coilovers install thread.
If you aren't lowered, I don't think you'll run into any fender or other interference problems, at all.
Edit: right, you plan on lowering. Well, it's case by case, but you should be fine, as long as your dampers match up. I wouldn't run lowering springs on the stock shocks.
sheekeebut is offline   Reply With Quote
Old 04-02-2015, 07:35 PM   #3
MountainMan
Thanks for the response, I was hoping they would work out. Now I will need to start researching suspension setup and coilovers for the yaris; this stuff is addicting and I already have two other money pits.
One Question though, do the sedans have larger wheelwells than the hatchbacks because I have notice the same wheel and tire size combo seems to look smaller on the sedans? or is it just an illusion caused by the bigger car?
Headrest Question Shroomster Third Gen Yaris General Discussion 5 06-05-2015 11:28 PM
Fitment Question SeriousBlack Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 11-17-2012 06:12 PM
Fitment Question..help 8thcivic07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 04-24-2010 02:09 AM
Wheel fitment question helladrift Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-02-2008 12:06 AM
Tire Fitment question Ryu Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 01-14-2007 01:47 AM
