Old 08-11-2016, 04:30 PM   #1
smb24601
Drives: Yaris 07, Delorean 82
Fusible link wiring diagram
Not sure if new thread was needed or not for this. However my red electrical tape method of marking which wire was which failed me. I had to cut the wires to replace the Fusible link and now am having trouble determining which one is which. I am having trouble finding the wiring diagram for this. Any help? Thanks
smb24601 is offline   Reply With Quote
Old 08-11-2016, 05:11 PM   #2
One of your wires (curved one) appears longer than the other. I suspect this is the one that goes to the battery clamp side of the fusible link. Don't have access to my car right now to do my own visual.
Old 08-11-2016, 05:53 PM   #3
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
One goes to the starter, the other goes to the alt. I would get a test light and probe each end and see which is which. I will have to do some digging to see what mine was. I know I just used a multi-fuse block when I did my battery relocation.
Edit: After looking at some diagrams, I believe the Alternator cable gets the fuse, and the starter cable goes straight to the 12v+ terminal. I know the littler white wire also got fused.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed.
Future: Turbo.
brushforhire is offline   Reply With Quote
Old 08-11-2016, 06:26 PM   #4
smb24601
So how can I determine which one is the alternator even with a multimeter. Both the ones with the plastic connectors are still intact, I was able to get those out easy.
Old 08-11-2016, 08:34 PM   #5
Put the meter in resistance mode and check for continuity (<2 ohms) between each wire and the lug on the alternator. The one to the alternator goes to the rear terminal.
Old 08-13-2016, 06:02 PM   #6
smb24601
OK, Thanks. Once I started putting everything back in everything fell into place very easily. End result pictured. Thanks for everyone's help.
fusible link, positive battery terminal
Fusible link and Terminal End Removal smb24601 DIY / Maintenance / Service 8 08-11-2016 04:16 PM
Wiring Diagram for under bonnet (hood?) fusebox azeeroth DIY / Maintenance / Service 5 11-11-2013 09:22 PM
MK1 Yaris SR - Wiring diagram. YarisSR General Yaris / Vitz Discussion 2 08-03-2011 04:44 PM
Wiring diagram? fwynn DIY / Maintenance / Service 4 05-05-2010 10:00 PM
NEED TPMS Wiring Diagram please mikenacarato DIY / Maintenance / Service 9 02-12-2009 12:55 AM
