Old 05-23-2017, 03:14 PM   #1
Blaze
Drives: Toyota Yaris T2 1.0 VVTi
Question Removal of Upper Glovebox Door
Hello all,
First of all I'm new to this forum, and forums as a whole, so sorry if this is in the wrong place. I did use the search function to try and find posts and threads on this topic, but found nothing useful. Correct me if there is anything.
I have recently bought a 2003 Toyota Yaris T2 as a first car. Haven't actually driven it yet as I haven't passed my test (failed for running a red light ). Over the past month or so I've been trying to fix it up, as it was cheap and needed work. Already done the clutch, replacement of brakes, some new anti roll bar parts, cables, etc..
One of the last parts left to do is fix the upper glovebox door, which is hanging off. The actual glovebox is fine, but the hinges on the upper door are broken. I've seen removal videos for a Prius, and a guide for the newer Yaris, but none of which really helped.
What do I have to remove to get to the mechanism for the door? I assume I have to remove the upper dashboard? Any tips or guidance would be helpful.
Thanks very much. And if you have anything else that I should do to my Yaris before I start driving, let me know. Would definately like to put a few T-sport parts on it at a later date (but I won't post about that here lol, wrong place. I know that much 😉)
Thanks.
Blaze is offline   Reply With Quote
Old 05-23-2017, 08:16 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I know the next generation requires the whole dashboard be removed, but can't comment directly on that version since we didn't get it in the States.
cupboard, dashboard, glovebox, interior, storage
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 01:24 AM
Door latch removal Carolyn UK 8 11-01-2013 03:37 PM
2007 Door Removal spottynatty DIY / Maintenance / Service 1 11-09-2012 07:14 AM
Yaris 1.0L GS 2000 Driver's Door Panel Removal milooshea DIY / Maintenance / Service 3 01-30-2011 12:20 PM
