Old 04-18-2022, 10:24 AM   #1
bluefever00
Drives: 2008 Sedan
Front wheel bearing
I have a 2008 yaris without abs. I replaced a front wheel bearing 9 months ago with the beck/arnley one. It has failed 8,000 miles later. Would anyone happen to know if the abs one can be used for non-abs? The only non-abs one I see is the same one. The measurements look identical.
bluefever00 is offline   Reply With Quote
Need front wheel alignment specs Rob888 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-13-2023 11:00 AM
Need front wheel alignment specs Rob888 DIY / Maintenance / Service 1 03-05-2020 03:53 PM
Can't find front hub bearing assembly with ABS anywhere! PrettyWreckless DIY / Maintenance / Service 5 04-09-2018 03:15 PM
Mixing wheel sizes. front 195/60r15, back 195/65r15 (or viceversa) badillin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-04-2017 07:10 PM
10mm or 15mm wheel spacers for front wheels? b20vteg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-05-2014 11:08 AM
