Old 01-21-2013, 08:08 PM   #1027
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Originally Posted by tooter View Post
In normal driving it doesn't bog down like stock when you let out the clutch. and you can feel it come on stronger at around 3,000 rpm on up. The larger bore of the throttle body now better matches the increased flow abilities of the tooter. It feels lots more gutsy.
Now some of this effect is simply the fact that when you push on the gas pedal, the larger throttle body's butterfly is letting in more air for the same throttle position.
But the biggest difference is when the throttle is to the floor...
Wonder how it would handle a good AEM FIC tune. :)
JustDidIt is offline   Reply With Quote
Old 01-21-2013, 08:56 PM   #1028
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Here's the video of today's dyno run...
http://www.youtube.com/watch?v=nDjz-3U7p5w
Old 01-21-2013, 09:07 PM   #1029
tooter
play every day
tooter's Avatar
Originally Posted by etherdude View Post
tooter,
So glad you got positive dyno numbers. I think the engine looks MUCh better without the plastic cover. I like to see the mechanical bits and pieces. Also, the whole thing looks much more "gnarly" with the DOHC valve cover showing instead of some stylized plastic.
Doug
Hey Doug,
Thanks, I'm really happy it makes more power... and most importantly with no loss of driveability or mileage. As much as I've been messing around with the Yaris, it's still our daily driver.
Yeah, I'm kind of liking the all aluminium look, too... especially as everything has the same even pearly matte finish.
Greg
Old 01-21-2013, 09:16 PM   #1030
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Now THAT is what I call some great HP/TQ gains. Not only is your peak HP better, but your TQ numbers after 4k rpms look great. I bet the car doesn't feel like it's running out of breath so much in the top end like these engines do right before redline.
Congrats on getting those numbers. You've worked hard for it! I'm glad it all worked out in the end, 110 whp isn't bad at all for a car that was rated 108 hp at the crank, with only bolt-ons!
Now I really can't wait to get a manifold and stick on this 1ZZ throttle body I have.
4/20 NEVER FORGET is offline   Reply With Quote
Old 01-21-2013, 09:53 PM   #1031
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ Vtec really kicked in at the end yo!
Old 01-21-2013, 10:11 PM   #1032
tooter
play every day
tooter's Avatar
You're right... the engine pulls strong right up to the top now!
Just be sure to break off the epoxy and turn out that little idle screw about one turn before you even install your 1ZZ. It should work just fine as long as the butterfly can close enough for a nice slow smooth stable idle.
I'm so pleased how this has all worked out. The combination of the larger manifold and larger throttle body added up to doing more than each component could do alone.
...and I'm still not done yet. I have some other experiments I'm going to be trying out in the near future.
Old 01-22-2013, 10:06 AM   #1033
4/20 NEVER FORGET
Long-tube header? Either way, I look forward to more updates.
Old 01-22-2013, 08:22 PM   #1034
tooter
play every day
tooter's Avatar
Namer convinced me not to mess with my header. Anyways, I like the Weapon R design and so will be leaving it as it is. I do have some more experimental intake manifold ideas that I want to see what happens if I do them. It's like following a tiny silver thread and you never know where it leads.
Old 01-22-2013, 09:09 PM   #1035
4/20 NEVER FORGET
I was also going to guess exhaust... but with you living in Los Angeles, I imagine you cannot even think about messing with the catalytic converters without fear of the man breaking down your door.
I'm about to move to a full 2.25" header-back exhaust using a OBX exhaust system as a base along with a single 2.25" magnaflow cat, 2.25" magnaflow resonator and 2.25" magnaflow muffler. I've also been thinking about buying another DC header and having the collector modified to 2.25", being that it is 2" now. I know there is more HP in there if the exhaust system can get freed up a little more. 2" seems so small for a collector on these headers, all of the 1.6L Honda's I worked on were either 2.25" or 2.5".
Either way, I need to find a shop to get this thing dyno'd so I can get a baseline. Thanks for so diligently getting your car dyno'd, it's great to see actually numbers instead of 'seat of the pants' reviews on stuff.
Old 01-23-2013, 01:45 AM   #1036
tooter
play every day
tooter's Avatar
You're right. I want to keep it smog testable. The way it is now, I can still run everything the way it is and simply stick on the stock airbox...
...and it'll smog test just fine.
Yes. A baseline is valuable information. A dyno is the only way to know exactly what's going on.
The graphs are honest and all done under the same conditions. Nothing was done to either enhance or diminish the results. I did three stock baseline runs, three with the tooter alone, and three with the tooter and the 1ZZ throttle body, and posted the best run from each set.
Old 01-24-2013, 12:17 PM   #1037
tooter
play every day
tooter's Avatar
Harry, at HK Motorsports dyno shop suggested tuning would increase the power but I won't be doing that. It already does good enough with the stock tune and regular pump gas... and I still want it to be able to pass the smog test. So I'll leave that for someone else to experiment.
Old 01-24-2013, 12:45 PM   #1038
^ Hopefully you'll pass visual. It does look stock, but it isn't, and technically should not pass.
But hey, it's a 2012 right? You have at least five more years I think. I haven't had to smog my '07 yet!
Old 01-24-2013, 01:12 PM   #1039
tooter
play every day
tooter's Avatar
I have a good smog guy I've gone to for years who is a fellow veteran. If there are no lights or codes and the tail pipe emissions are good. It'll pass for sure. Even with all the crazy stuff I've tried, It's still never triggered a CEL light, except one time I forgot to plug in the MAF sensor.
Old 01-26-2013, 06:55 PM   #1040
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
so absurd you can't pass smog with mods. where is the scca on that front?
Colin Chapman disciple
Old 01-26-2013, 07:43 PM   #1041
tooter
play every day
tooter's Avatar
As long as there are no codes generated by the computer, the fuel vapor recovery system works properly, and the tailpipe sniffer smells clean exhaust... it'll pass.
Old 01-26-2013, 07:47 PM   #1042
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I work on A LOT of hondas. Most of the header outlets are 2". Even for a b18 teggy I worked on last tuesday. Dont let the small collector fool you. 2" is just about perfect for our motors. You want the exhaust gases to be at a high velocity when leaving the motor. The stronger the pulse...the stronger the vacuum behind that pulse. Thats what makes power. The larger the pipe the weaker the pulse strength would be and it will be traveling at a slower rate
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-27-2013, 02:22 AM   #1043
baseballfan416
Drives: 2017 L 3-door
I may be late to the show but...
I think there's still hp left on the table. Looks like the 108 whp is just about every bolt-on mod aside from the crank pulley, which is considered by many to be the best "bang for the buck."
baseballfan416 is offline   Reply With Quote
Old 01-27-2013, 02:31 AM   #1044
tooter
play every day
tooter's Avatar
I don't believe that the pluses outweigh the minuses in that regard, as I don't think it's a good idea to remove something from an engine that provides the useful purpose of absorbing crankshaft vibrations.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
