Old 08-01-2013, 10:23 PM   #1351
Viperoni
Drives: 2005 Toyota Echo
Lookin good, can't wait for the driving report tomorrow!
2006 Saturn Ion Redline
Old 08-01-2013, 10:50 PM   #1352
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
It should work just fine since Toyota had already put the same design on their cars...
I haven't been able to find this manifold in the US. However, it was installed on 1998 Toyota Starlets in the UK and in Pakistan.
I'd love to find one and see if the tooter flange would fit onto it, because building the tooter et took a lot of work.
Old 08-02-2013, 02:22 AM   #1353
tooter
play every day
tooter's Avatar
Originally Posted by JustDidIt View Post
That looks awesome!! I need to make a trip up to LA and come check the work out in person....
Let me know when you'd like to visit. That would be fun.
Greg
Old 08-02-2013, 10:46 PM   #1354
tooter
play every day
tooter's Avatar
Got the tooter et up and running this morning...
I messed up a little on the attitude of the throttle body as the rotation is about 30 degrees off, but it's not enough to keep it from working.
Drove it only a little bit today because of work, and it drives really good even with ECU just relearning the new operating parameters. It's just as quiet as stock in regular driving, but makes a really cool swooshing bwwwaaa sound when you step on the gas pedal. I think that's because there are no baffles in the plenum like there are in the regular tooter. And also I did a lot of porting on the mouths of the runners so that they are way more open and less restrictive than they were before.
I'm going to drive it around until everything is acclimated and then put it on the dyno, as that's the most trustworthy indicator of any changes.
Old 08-03-2013, 07:14 AM   #1355
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Old 08-03-2013, 08:03 AM   #1356
Silver Streak
Silver Streak's Avatar
Drives: 2010 Yaris sedan silver
k&N Pannel air filter
Trd Exhaust
Trd Rear Sway Bar
Silver Streak is offline   Reply With Quote
Old 08-03-2013, 09:43 AM   #1357
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Oops, I guess you could cut it off again and have it rewelded.
Old 08-03-2013, 09:49 AM   #1358
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
relocate the battery or get a capacitor style battery like CTScott is experimenting with and it will be gravy.
Old 08-03-2013, 11:55 AM   #1359
^ A small dry cell battery would work great, that's what I use in my cars. Mine weighs 4 pounds.
Way to go, tooter
Old 08-03-2013, 12:21 PM   #1360
tooter
play every day
tooter's Avatar
That's exactly what I'm going to do. It's a small issue and simple to resolve. That's the beauty of aluminum. It's easy to work with. But before I do that, first I want to drive it around and then put it on the dyno, because rotating the throttle body is only for aesthetics and isn't going to make any difference in how it runs.
Old 08-05-2013, 09:47 AM   #1361
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Can't wait to hear the audio of the intake!
JustDidIt is offline   Reply With Quote
Old 08-05-2013, 11:41 AM   #1362
tooter
play every day
tooter's Avatar
Took it for a long drive up north on the 5 freeway (65-80mph) and up to Mt. Pinos and got 42.6 mpg in 248 miles.
It's ready to dyno now, so when work allows I'll be off to Harry's shop.
Old 08-05-2013, 12:05 PM   #1363
Flipper_1938
How does that compare to other combos that you have run on that car?
Old 08-05-2013, 10:29 PM   #1364
tooter
play every day
tooter's Avatar
These are the statistics so far...
1,931 miles with the stock intake manifold got an average of 35.9mpg.
5,592 miles with the tooter got an average of 36.4mpg
(although that included a full winter of cold weather driving which always yields lower mileage)
248 miles with the tooter et got an average of 42.6mpg
(although that was just one fillup with a lot of high speed freeway miles)
The best prior fillup was 39.1mpg.
(with freeway driving)
I'll post more mileage figures when I rack up enough to be able to get an accurate indicator. And I'll be down at Harry's dyno shop as soon as I can find a break from work.
Old 08-05-2013, 10:31 PM   #1365
Bluevitz-rs
The mileage increase is astonishing
Old 08-05-2013, 10:52 PM   #1366
tooter
play every day
tooter's Avatar
Well, remember that was just one long trip, and most of it was between 65mph and 80 mph. It'll settle down to a more reasonable average in a little while.
I can say this. The engine runs really good on the freeway, and if I had to hazard a guess why, it would be porting the mouths of the runners. Those rough welds were really overhanging the intakes.
The dyno will tell the tale.
All the bullshit ends there.
Old 08-06-2013, 01:54 AM   #1367
JustDidIt
JustDidIt's Avatar
This is making me think that the 1NZ could benefit from longer intake runners...than oem. Let see what the DYNO says and some more daily driving testing. :)
BTW.. Awesome!
Old 08-06-2013, 02:57 AM   #1368
tooter
play every day
tooter's Avatar
BTW.. Awesome!
Thanks, man.
It's fun experimenting just to see what will happen. The tooter's runners are one inch longer than stock, which is only 5% longer. However, they are oriented completely different than the stock runners in that they look directly at the throttle body like an exhaust header...
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
