Old 08-06-2009, 06:31 PM   #1
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
my service book on my 2009 calls for it @120K miles. At that point the car will probably be worth so little I'd be inclined to just drive until it dies.
Lewis is offline   Reply With Quote
Old 08-08-2009, 05:55 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
If you read PK's link on what that checkup entails you'll see that its an audio inspection meaning if your valves arent making any abnormal noise then they're ok.
Old 08-08-2009, 11:02 AM   #3
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
A valve clearance inspection is not a "audio inspection"!!! It's a physical inspection using a feeler gage to measure clearances. What if your valve clearance is too small? They wouldn't be making any noise then, yet undersize clearances can burn out your valves!
Don't depend on noise to determine if the valves are OK. It can't be done.
Reddog99 is offline   Reply With Quote
Old 08-08-2009, 11:49 AM   #4
jambo101
jambo101's Avatar
Heres the link to the maintainance schedule check out the 7th item in the 64k inspection http://xws.xtime.com/xmmmenu/?varian...estimate=false
I agree not much of a valve inspection.
Old 08-08-2009, 01:51 PM   #5
1stToyota
1stToyota's Avatar
And Mitchell repair says to LISTEN for noise, then check for engine smoothness, before going to the actual trouble of pulling cyl head cover and checking clearance with a gauge.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
PVC valve routine? N9QGS DIY / Maintenance / Service 13 05-26-2009 07:32 PM
uhoh....valve tapping already???? iwantayarisnyc General Yaris / Vitz Discussion 13 12-11-2008 12:56 PM
excessive valve and or engine noise? thomasward00 General Yaris / Vitz Discussion 3 06-07-2007 12:34 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
