![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
If you read PK's link on what that checkup entails you'll see that its an audio inspection meaning if your valves arent making any abnormal noise then they're ok.
#2 | |
![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Don't depend on noise to determine if the valves are OK. It can't be done. |
Heres the link to the maintainance schedule check out the 7th item in the 64k inspection http://xws.xtime.com/xmmmenu/?varian...estimate=false
I agree not much of a valve inspection. |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
And Mitchell repair says to LISTEN for noise, then check for engine smoothness, before going to the actual trouble of pulling cyl head cover and checking clearance with a gauge.
| Valve Noise | barryware | DIY / Maintenance / Service | 25 | 02-13-2013 02:39 PM |
| PVC valve routine? | N9QGS | DIY / Maintenance / Service | 13 | 05-26-2009 07:32 PM |
| uhoh....valve tapping already???? | iwantayarisnyc | General Yaris / Vitz Discussion | 13 | 12-11-2008 12:56 PM |
| excessive valve and or engine noise? | thomasward00 | General Yaris / Vitz Discussion | 3 | 06-07-2007 12:34 PM |
| 2007 Yaris LB - Valve Adjustments | Pavel Olavich | DIY / Maintenance / Service | 3 | 03-30-2007 05:34 PM |
