Old 04-12-2007, 04:40 PM   #4
BailOut
Steals terrorist's lunch
BailOut's Avatar
We hashed this all out in another thread that you can search for if you'd like deeper information, but here's the skinny:
Max sidewall pressure is the *minimum* pressure you should use on the Yaris. Several of us on CleanMPG.com run the RE92's at 60 PSI and have gotten not only nice MPG increases (due to lower rolling resistance) but much greater life out of the tires (the first of us to go to 60 PSI just hit 85,000 miles on the original tires - that's unheard of at 32 PSI).
Toyota's recommendation of 32 PSI is based solely on a comfortable, cushy ride rather than anything to do with performance, stability, tire wear, etc.
- Brian
Share the Road
BailOut is offline
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 07:29 AM
Tire Pressure and Gas Economy KittenRD General Yaris / Vitz Discussion 11 01-25-2007 11:54 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 01:37 PM
stock tire pressure... argylesocks Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-16-2006 01:28 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
