Old 04-25-2009, 08:53 PM   #11
cyberfrogg
cyberfrogg's Avatar
Drives: Yaris Sedan S
The pin 4 connection is the big issue I believe. Only the OEM wire should be connected there.
Try this:
1. Disconnect both of your wires from Pins 3 and 4.
2. Pop the pin out of pin 3 (or, if your harness just has bare ends, snip the wire going to pin 3, leaving an inch or so to connect to.
3. Connect one of your wires to one side of the snipped wire (harness side) and the other to the other side (connector side).
I tried doing this and it didn't work... My fog lights would not turn on. I snipped the original yellow wire in pin 3 and connected my green wire to it (so now the green wire is connected to pin 3 directly) and then I got my blue wire and connected it to the other piece of the yellow wire that was hanging.
this is what it looked like before:
And it looks something like this now:
(the black rectangle on the bottom just represents like the switch of the fogs...)
Did i do something wrong? Now that its wired like this my switch works just as its supposed to but my fog lights wont turn on at all anymore... =/
please help!
cyberfrogg is offline   Reply With Quote
Speakers wires : how to identify + and - ? hystria In Car Entertainment + Electronics (audio / video / alarm) 23 05-27-2017 10:43 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Installing a remote starter without cutting factory wires? yaris08ce In Car Entertainment + Electronics (audio / video / alarm) 36 04-23-2009 08:59 PM
Ground Wires dngz Performance Modifications 8 11-26-2006 11:54 PM
Q about Routing wires to the engine compartment W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 10 11-01-2006 07:36 PM
