#19 |
#20 |
#21 |
oooohhhhh! No, I didnt do that. I just inserted the wires with the existing ones. Blue into pin 3 and green to pin 4. Was I supposed to remove the existing wire in pin 3? what would that do?
#22 | |
Try this: 1. Disconnect both of your wires from Pins 3 and 4. 2. Pop the pin out of pin 3 (or, if your harness just has bare ends, snip the wire going to pin 3, leaving an inch or so to connect to. 3. Connect one of your wires to one side of the snipped wire (harness side) and the other to the other side (connector side). |
#23 |
okay I'll do that when I get home. =] thanks!
I hope this works! |
#24 |
The relay from what i have been told should also have a
inline resister as per photo of this relay |
#25 | |
![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
Purchase the foglight stalk. The install is SOOOOOO much simpler and no messing with firewall and interior wiring. Plus, the fog light stalk is how it would come if you ordered your car with fogs from Toyota factory directly. |
#26 | |
#27 | |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
#28 | |
http://www.yarisworld.com/forums/sho...og+light+stalk |
#29 |
やりすぎだ~
Thanks all. I installed the foglights and figured that I don't HAVE to have the foglight indicator on in the instrument panel since it indicates "on" on the button itself.
#30 | |
This is the way I did mine. |
#31 | |
this is what it looked like before: ![]() And it looks something like this now: ![]() (the black rectangle on the bottom just represents like the switch of the fogs...) Did i do something wrong? Now that its wired like this my switch works just as its supposed to but my fog lights wont turn on at all anymore... =/ please help! |
#32 |
What do you mean by switch works just as it's supposed to? Do you mean that when you press the fog switch, the dash indicator comes on, but the lights don't?
#33 |
The fog light symbol on the switch turns along with all my other interior lights, which is good. And when I press the switch, the little led indicator turns on as its supposed to. The only thing is the fog lights themselves dont turn on and therefore the symbol on the dash doesnt turn on. So the lights on the switch do what theyre supposed to do. Before I wired it this way, the little led would be on all the time (except for when I had my fogs in use). So in a sense, it was backwards. And now it works, but my fogs dont turn on...
#34 |
How many wires connect to your switch?
#35 |
Four. This is an old pic I had. Its the only one that kinda shows em.
![]() I have two Greens, one blue, and a ground... the black one. One green I have wired underneath the gear shift so that the fog light symbol gets light from it and turns on when I turn on my lights inside. The other green and the blue are what are messing me up. |
#36 | |
This one seems to best match your description, and it requires modification to connect to the oem wiring: http://www.yarisworld.com/forums/showthread.php?t=9473 |
| Speakers wires : how to identify + and - ? | hystria | In Car Entertainment + Electronics (audio / video / alarm) | 23 | 05-27-2017 10:43 PM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 11:48 AM |
| Installing a remote starter without cutting factory wires? | yaris08ce | In Car Entertainment + Electronics (audio / video / alarm) | 36 | 04-23-2009 08:59 PM |
| Ground Wires | dngz | Performance Modifications | 8 | 11-26-2006 11:54 PM |
| Q about Routing wires to the engine compartment | W.A.S.P | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 11-01-2006 07:36 PM |
