#1351 |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
Lookin good, can't wait for the driving report tomorrow!
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
#1352 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
It should work just fine since Toyota had already put the same design on their cars...
![]() ![]() I haven't been able to find this manifold in the US. However, it was installed on 1998 Toyota Starlets in the UK and in Pakistan. ![]() ![]() ![]() I'd love to find one and see if the tooter flange would fit onto it, because building the tooter et took a lot of work.
#1353 |
play every day
#1354 |
play every day
Got the tooter et up and running this morning...
![]() ![]() I messed up a little on the attitude of the throttle body as the rotation is about 30 degrees off, but it's not enough to keep it from working. Drove it only a little bit today because of work, and it drives really good even with ECU just relearning the new operating parameters. It's just as quiet as stock in regular driving, but makes a really cool swooshing bwwwaaa sound when you step on the gas pedal. I think that's because there are no baffles in the plenum like there are in the regular tooter. And also I did a lot of porting on the mouths of the runners so that they are way more open and less restrictive than they were before. I'm going to drive it around until everything is acclimated and then put it on the dyno, as that's the most trustworthy indicator of any changes. |
#1355 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
#1356 |
![]() ![]() Drives: 2010 Yaris sedan silver Join Date: Jul 2012
k&N Pannel air filter Trd Exhaust Trd Rear Sway Bar |
#1357 |
Oops, I guess you could cut it off again and have it rewelded.
#1358 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
relocate the battery or get a capacitor style battery like CTScott is experimenting with and it will be gravy.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#1359 |
^ A small dry cell battery would work great, that's what I use in my cars. Mine weighs 4 pounds.
![]() Way to go, tooter
#1360 | |
play every day
#1361 |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
#1362 |
play every day
Took it for a long drive up north on the 5 freeway (65-80mph) and up to Mt. Pinos and got 42.6 mpg in 248 miles.
![]() It's ready to dyno now, so when work allows I'll be off to Harry's shop. |
#1363 |
#1364 | |
play every day
1,931 miles with the stock intake manifold got an average of 35.9mpg. 5,592 miles with the tooter got an average of 36.4mpg (although that included a full winter of cold weather driving which always yields lower mileage) 248 miles with the tooter et got an average of 42.6mpg (although that was just one fillup with a lot of high speed freeway miles) The best prior fillup was 39.1mpg. (with freeway driving) I'll post more mileage figures when I rack up enough to be able to get an accurate indicator. And I'll be down at Harry's dyno shop as soon as I can find a break from work. |
#1365 |
The mileage increase is astonishing
#1366 |
play every day
Well, remember that was just one long trip, and most of it was between 65mph and 80 mph. It'll settle down to a more reasonable average in a little while.
I can say this. The engine runs really good on the freeway, and if I had to hazard a guess why, it would be porting the mouths of the runners. Those rough welds were really overhanging the intakes. ![]() The dyno will tell the tale. All the bullshit ends there.
#1367 | |
BTW.. Awesome! |
#1368 | |
play every day
![]() It's fun experimenting just to see what will happen. The tooter's runners are one inch longer than stock, which is only 5% longer. However, they are oriented completely different than the stock runners in that they look directly at the throttle body like an exhaust header...
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
