Old 06-30-2009, 10:49 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
Rub a dub dub...
I have an 09 3-door with OEM 185/60/15 on MB 'Weapon' wheels (15X7 4-100 35GM) with 13mm rear hub spacers. Also, car is lowered on DF210's. The wheels and tires look awesome, but I'm getting some pretty annoying rubbing in the rear when going over dips/valleys in the road. It doesn't seem to happen with normal up and down bumps/potholes, just any time the rear end dips down more than the front. It seems to be only happening on the right rear tire, which is weird.
Also, the front left tire is rubbing when I turn against the locks to the right, such as in parking or pulling into my driveway.
Is there anything I can do to eliminate the rubbing? I know it's only rubbing on plastic (I hope!), but it sounds kinda scary, especially to passengers who aren't used to the sound.
MGargano is offline   Reply With Quote
Aftermarket exhaust systems that do not rub on the road! fuji Performance Modifications 10 04-28-2009 06:22 AM
Does +43mm rub? Split Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 02-28-2009 07:39 PM
New Wheels and TRD springs tires rub gmodder Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-25-2009 11:21 AM
want 2 lower with tein but have tyre rub HELP! MR. CANTON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-24-2007 04:16 PM
Ruba a dub dub in the rear slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2007 08:27 PM
