Old 08-29-2014, 09:10 PM   #1
ApolloJA
Drives: Vitz RS
Question Lightweight Flywheel
ok so im considering to get the lightweight flywheel from MI
http://shop.microimageonline.com/Lig...-2-617-5ST.htm
However, just need a few reviews on it like if it makes a huge difference/how it feels and if i can use it with the stock clutch
ApolloJA is offline   Reply With Quote
Old 08-29-2014, 09:42 PM   #2
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
yes, huge difference, granted mine went in with a stage 4 springless 6 puck clutch so that added to it, but the increased rev rate and amplification of torque will be noticeable.
further information on what I did.
http://www.yarisworld.com/forums/sho...lywheel&page=2
Old 08-30-2014, 06:45 PM   #3
ApolloJA
Drives: Vitz RS
Sounds like a good buy then but did u upgrade your clutch because it is required?
Old 08-31-2014, 11:06 AM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
It is not required to upgrade the clutch, however if you ever want to install a racing clutch the time is to do it when you put in a lightweight flywheel, because it is in the same area and needs to be taken out anyways.
Colin Chapman disciple
Old 12-26-2014, 11:38 AM   #5
marion2
Drives: Yaris Sedan YRS
Does this lightweight flywheel from MI will only be applicable on a 1nz-fe or is it interchangeable to 2nz-fe?
marion2 is offline   Reply With Quote
clutch, flywheel, lightweight, transmission
Lightweight Flywheel for the Yaris? NonStopTuning Performance Modifications 51 03-21-2014 02:57 PM
Questions for new flywheel and clutch mrbond Performance Modifications 11 07-11-2013 07:17 AM
Flywheel question-1nz conversion-2003 Model Echo56 DIY / Maintenance / Service 0 05-21-2013 10:42 PM
CCI Lightweight Flywheel Review H3LlIoN Performance Modifications 32 05-06-2011 11:51 AM
lightweight flywheel from fidanza dngz Performance Modifications 34 02-03-2009 11:02 PM
