Old 09-25-2022, 10:46 AM   #1
stiglitz
Drives: 2015 Toyota Yaris MT
Spring, shocks/struts, and rear sway bar compatibility?
I have a 2015 Toyota Yaris L (2-door hatchback manual transmission)
Are the following parts compatible? They're all listed for 07-11 model years but from my research it seems not much has changed suspension-wise between the older and newer hatchbacks.
Bilstein B8 front strut (22-236296)
Bilstein B8 rear shock (19-236315)
Tein S Tech lowering springs (SKC10-AUB00)
TRD rear sway bar (PTR1152071)
stiglitz is offline   Reply With Quote
Old 09-25-2022, 11:02 AM   #2
stiglitz
I found the answer in this post thanks to mitch9521
Old 09-25-2022, 11:44 AM   #3
The appetite for modding this platform really started its demise sometime in 2010, two years into the gen2 facelift. Nobody does gen3 product development, nor have any companies that supported the gen2 with aftermarket products even bothered to fitment test on the gen3 and update their compatibility databases.
It's pretty much come down to someone taking an educated guess, taking the plunge, and then word gets spread like it did in this case.
In a nutshell, engine, drivetrain, brakes, suspension all the same gen2 to gen3.
Old 09-28-2022, 09:40 PM   #4
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
The gen 3s get more love in Japan, just shipping stuff to Canada is brutally expensive post Covid or else I would have a full Vitz G's body kit on my car. Our dollar going down the tubes does not help either.
Its too bad cause these cars are super light and tossable, they're considerably lighter than Honda Fits and those have lots of aftermarket support.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 09-29-2022, 05:07 PM   #5
Neinris
I bought my Bilstein B8s from RockAuto.com, and they're cheaper compare to that eBay seller, but you'd have to pay for shipping. Ironically, I bought the Tein's lowering springs from eBay, for only $120.
Old 10-25-2022, 05:24 PM   #6
stiglitz
Just wanted to update everyone on this thread: I completed the install and all parts listed in the original post bolted right up without a problem (NOTE: I went with Megan Racing springs, not Tein). Suspension components are indeed the same from Gen 2 to Gen 3. I’ll create a thread and post photos another day. Thanks for your help!
Old 10-26-2022, 10:15 AM   #7
Neinris
Can't wait to see the pics. I haven't had the chance to do it, but I'll be trimming the bump stop by half an inch. I felt a slight bottom out when I hit a bump going 70MPH.
Does anyone know the spring rates for the Megan Racing springs?
According to the Tein website, the S.Tech springs that I have are 3 kgf/mm on the front and 3.5 kgf/mm on the rear.
https://www.tein.com/tech_info/l70.html
Old 10-26-2022, 04:03 PM   #8
https://www.yarisworld.com/forums/sh...6&postcount=20
Old 10-27-2022, 12:22 PM   #9
Neinris
Thanks WeeYari!
Just to put it out for everyone without having to click at the links provided, the Tein S.Tech are 170lbs/in in the front and 200lbs/in in the rear, while the Megan Racing Springs are 126lbs/in and 140lbs/in respectively.
Old 01-04-2023, 09:05 AM   #10
Buba1
Drives: '18 Yaris SE
So basically, if I were to order springs or coilovers for an older gen, it should fit my '18 Yaris? Because I cannot find anything that goes with my year anywhere.
Buba1 is offline   Reply With Quote
Old 01-04-2023, 10:02 AM   #11
Correct.
Old 01-04-2023, 09:07 PM   #12
Buba1
Correct.
Thanks for confirming. Makes things a lot easier to shop for now.
bilstein, compatible, lowering, tein, trd
Rear Sway bar, worth it ? Other options? road_junky Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-06-2014 10:08 AM
WTB: Weapon R Dragon Intake and TRD rear sway bar. TerenceCruz Willing to Buy by private party 2 07-28-2013 05:13 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Is the TRD rear sway bar a worthwhile upgrade? YellowJolt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 07-15-2009 08:07 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
